Question about Apple iPhone Smartphone
Sms operation with 1.1.4 fw, my keypad does not fully function (space bar, numeric key) when trying to sms. RC
  • 1,879 Answers
Greetings,
For instructions too long to post in here - click on this link
sms operation - fxnlogo_s.png Technical Support, Instructions & Repair Service
Posted on Aug 28, 2008
How do you get to use the space bar in the button zero
I'm not entirely sure what you. If you're using the numeric keypad to type out a 'TEXT', then you'll want to use the '#' key in order to add spaces. The actual key pad has dedicated buttons for '0' and 'SPACE'.
Jun 05, 2014 | Samsung SCH-U450 Cell Phone
How to enable numeric pad
usually on the Toshiba laptops you need to hold down the function key to get your numeric pad working. try looking for a key labeled 'fn' down to the left of the space bar. Once holding it down, try using the number pad
Apr 28, 2013 | Toshiba Satellite Computers & Internet
My numeric keyboard is not working, the num lock is on.
Have you tried booting up in safe mode to see if it does the same thing? Also check your keyboard to see if there is some type of key combination that locks or unlocks the numeric keypad. If so, usually you will have to hit the FN key or the ALT key or the CTRL key plus some other key to get it to toggle.
Mar 31, 2012 | Toshiba Computers & Internet
Why my asus a3000 keyboard not function correctly when i push U I O P the function is number when i push this key
NumLk (Numbers Lock) has been turned on. Pushing U I O P results in 4 5 6 * and pushing J K L results in 1 2 3. NumLk allows a block of keys on the right side of the keyboard to function as a numeric keypad to facilitate easier entry of numbers or numeric related data. There is an indicator that will be on when NumLk is on. To turn NumLk off, you need to push the key that has NumLk on it. It may be combined with a function key in which case you will need to hold down the Fn key while pushing the NumLk. If you manage to push the right key(s), the NumLk indicator should turn off and the keyboard will revert back to its normal operation (without the numeric keypad).
Feb 07, 2011 | Computers & Internet
Restore my acer 3680 back to factor
to restore your system to factory default....restart the system..immediately hold the AltGr key(the one right to the space bar)down...and keep tapping the F10 key...you should screen that says windows is loading file..if not try a couple of times...once you get that screen...navigate through the screen ..this will help you restore system to factory default
let me know if this helps...
regards
Dec 29, 2009 | Acer Aspire 3680 Laptop
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
Nov 13, 2009 | Acer Aspire One AOA110-1113 Netbook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Ican"t type numbers can you please help
From Dell user manual:
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
  • To enable the keypad, press <Num Lk>. The keyboar2.jpg light indicates that the keypad is active.
  • To disable the keypad, press <Num Lk> again.
Jan 13, 2009 | Dell Inspiron 6400 Notebook
How do I use Dell inspiron 1300 keypad?
If you are referring to the Number keypad.
Tap the "Num lock" key and you will see a light flashing.
Make sure the light is on when you stop.
Now try the keypad.
Mar 15, 2008 | Computers & Internet
Iphone SMS problems
I found this solution posted as comment on this clip:
This following solution was suggested on youtube, it worked for me. There is one negative point about it: ALL YOUR OLD MESSAGES WILL BE DELETED
If you delete your sms.db file (located in: var\mobile\library\sms) it fixes it, you can open and send\recieve sms. i think the only permanent solution is to upgrade to 1.1.3 with itunes and start again (im asuming u got the bug using ziphone, i did). i installed isms as a backup sms service incase it stops working, which it does often. you cant look at recieved messages, but good for sending sms if sms.ap is playing up
to delete sms.db i use mobilefinder on my iphone
Dec 09, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
67 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
