Question about SanDisk Sansa Clip MP3 Player
Installation Just bought this Connected to PC went through hardware installation but ended with an error Now PC wont recognise it at all When I connect to either PC or laptop nothing happens Not even battery charge
  • Anonymous Sep 24, 2008
    MINE WONT CONNECT BUT IT WILL CHARGE HELP
  • buddrinkle Jan 26, 2009
    I had a 1GB prior to getting my 2GB clip. I didn't have any trouble with the 1GB.
    Now I find I cannot get this new 2GB to show the Sansa Player Icon when I go into MY COMPUTER. When I plug the clip into the USB port, it shows that it is connected, but the battery won't charge. I have Windows XP SP3.and I have tried every available USB port, but it's the same thing with every one. A window pops up to say that the computer cannot detect the clip or the USB port cannot detect the device.
    I tried it on another computer and everything worked perfectly. Obviously, the trouble is not the MP3 clip; it's the computer that's at fault. However, the information I want to download to the clip (Spanish Lessons) is stored on the computer that will not accept the clip.
    Any suggestions??
  • 8,596 Answers
Make sure hold/lock is not engaged.
Try another USB port.
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
I have a memory craft 12000 and I have installed the software. When I try to send an embroidery design from my PC to the sewing machine I gat a communication error stating that I need to connect the usb...
Suggestion - Your usb cable need to be installed first and recognised by your pc as "your new hardware is ready to be used"
or if not, may need to reinstalled your software ensure your usb cable is connected as well.
Oct 30, 2013 | Janome Sewing Machines
Not recognising hardware
The error code tells me the computer is not phisically connected to the device. Either the cable is bad, it is not connected in the right places or the port it is plugged into is bad. Try the device on a friends PC to confirm it still works. Then just rule out the unit, and cable. Lastly try plugging something else into the port and see if the PC likes that device. *mark*
May 07, 2010 | HP PSC 1410 All-In-One InkJet Printer
External hard drive device installer error
Has it got its own power supply or is it using a two USB ended cable. It could be your laptop cannot supply enough power via one USB port so that it really needs a two ended cable so that two USB ports will power it up. Try this Mark
Aug 18, 2009 | Hitachi 0A52126 120 GB SATA Hard Drive
USB
Install PC Suite -
If not Done -
Check Settings From Phone - USB Device > Select Data Transfer or PC Suite -
Or Format ur Mobile n Check From PC if Connected -
IF Not Connected CHeck My Computer Properties -
Then go to Hardware > Device Manager > See the Device is there Connected or Not -
Jan 14, 2009 | Nokia 3110 Cellular Phone
When i put the usb in the computer it doesnt connect
I would suggest that first you make sure that your computer is updated with Service Pack 2 or 3, DirectX9 or higher, and Windows Media Player 10 or higher. To do this, I went to Start -- Control Panel -- Windows Update. Then downloaded and installed all updates as required.
Secondly, I downloaded the codec for the portable device. To do this I pluged the MP3 Player into the USB port (still not recognised), went to Start -- Control Panel -- Printers and Other Hardware -- Add Hardware and this prompted the Hardware wizard. Clicked "Next" and selected YP-U3 from the list. Then selected "Install Automatically" and Voila! The codec was downloaded and the portable was recognised.
Jan 08, 2009 | Samsung YP-U3 MP3 Player
Have maxtor bought today my pc wont reconise it
The drive needs to be installed and recognised and then formatted
go to start/control panel,add new hardware and let windows search for the hard drive.
if it cannot find it then opt for a manual installation and follow the instructions
Dec 09, 2008 | Computers & Internet
PC & notebook wont recognise DV connection
Is your firewire controller turned on or enabled in the BIOS? Maybe its off. when your PC boots up, use the F2 key or del to get into th e BIOS, under peripherals, there may be a firewire controller that can be disabled/enabled. Check that and get back to us.
Mar 03, 2008 | Video Cameras
PC not recognising hardware
Sansas only work on WinXP or later. Win 2000, ME, 98 and 95 are not supported.
Jan 03, 2008 | SanDisk Sansa m240 MP3 Player
My samsung will not connect to my computer
please help!!!!!
i have a samsung GT-S5600V ive installed the software for it 'USB cable' and 'Samsung new PC studio' and ive connected my phone to the computer through the USB cable and its not searching for the device it keeps saying 'the device cannot be opened because another program is currently using it.close the program to connect the device.move to search new device' and im gettin really annoyed PLEASE HELP!
Nov 14, 2007 | Samsung YP-K3 MP3 Player
PC does not recognise TomTom
Dont use a HUB, connect it directly to the PC.
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Sep 03, 2007 | Tomtom One Europe v2 GPS Receiver
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
