Question about Sony Ericsson P990i Cellular Phone
Networks Hi, I have GPRS, Wi-Fi and 3G working on the phone. When at work I connect to the Wi-Fi and wants it to only use this network for internet and mail, but it seems phone chooses the one with the best signal (which is obviously 3G) and use that network then instead. How can I get it to use Wi-Fi alone?
  • Anonymous Mar 18, 2014
    can not get an wi fi connection signal to be able to use email or any other apps that need internet
Con el servidor remoto
Posted on Aug 28, 2008
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Tip
How to Speed Up Internet on my Touch Pro 2?
<p>The HTC Touch Pro smartphone 2 is avaialble for T-Mobile and Sprint subscribers, and uses the data network cell phone to connect to the Internet. While the Internet connection is based on a strong 3G connection for fast browsing, you can also activate the Wi-Fi device to connect to a wireless network. Available Wi-Fi networks within range of the Touch Pro will be displayed on the device are on the list of networks. Once connected, your Internet speed is capable of data based on the strength of the wireless signal to send. <br /> <p><br /> <p>1. Slide your finger on the "Home" screen to the tab "Settings" appears. Play the "Communications" button. <br /> <p><br /> <p>2. Touch "Wi-Fi" on the phone screen, then hit the wireless network is displayed in the "Discovered Networks" list. <br /> <p><br /> <p>3. Type the network security key using the onscreen keyboard, and press "Done" for the network to connect. A wireless signal appears at the top of your phone screen when connected to Wi-Fi network successfully <br /> <p>4. Touch "Back" to return to the "Communications" menu. <br /> <p><br /> <p>5. Play the "ON / OFF" in "communication" from the menu for Wi-Fi off. It is important to turn off the Wi-Fi functionality when not connected to a wireless network, because this mode the battery is not on. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to connect your Apple iPad to the Internet
Connecting your Apple iPad to the internet is very simple. When you use a application that requires internet capabilities your iPad will do several things.
-The iPad will attempt to connect using the last Wi-Fi network you used that is available.
-If no network you previously used is available, the iPad will show a list of networks in range. You can then tap a network and if needed, enter a password to join the network. Any network with a locked Icon will require a password. These are secure networks.
-If no networks are available or if you don't choose one, the iPad will then connect over a cellular data network.
What is the difference between a cellular and Wi-Fi network? A Wi-Fi network is generally faster, but covers less of an area. Think of your home wireless network, or a wireless network at a library. It has limited range. A cellular network is generally slower but covers a larger area. Normally, if you are connected to a cellular network you will see a 3G icon or E icon at the top of your device. Also, you normally pay to use a cellular network.
To see all the Wi-Fi networks in range: From the Home screen, choose Settings > Wi-Fi. Tap a network to join it.
-G33k
on May 17, 2011 | Apple iPad 16 GB 3G Tablet PC
MY SONNY ERICSSON X8 WHY I CAN'T GET THRU IN WIFI
To connect to a WLAN via Wi-Fi™:
  1. From the Home screen, find and tap Settings.
  2. Tap Wireless controls > Wi-Fi settings.
  3. Mark the Wi-Fi checkbox. Available Wi-Fi™ networks are displayed in a list under Wi-Fi networks. The available networks may be open or secured. This is indicated by the icon next to the network name.
  4. Tap a Wi-Fi™ network to connect to it. If you are trying to connect to a secured Wi-Fi™ network, you are asked to enter the security key for that Wi-Fi™ network before you can connect to it. The Wi-Fi™ connection is displayed in the status bar once you are connected.
Useful tip:
  • The next time you connect to a Wi-Fi™ network, the phone will remember the security key.
  • To enable Wi-Fi™ network notification of open networks, mark the Network notification checkbox.
  • To connect to another Wi-Fi™ network, just tap another Wi-Fi™ network in the Wi-Fi networks list.
  • To scan for Wi-Fi™ networks manually, press the Menu key and tap Scan. The phone scans for Wi-Fi™ networks and displays them in the Wi-Fi networks section.
You can also try updating your softwares by going to the sites below;
Update Service,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax8?cc=gb&lc=en
PC Companion,
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pccompanion/xperiax8?cc=gb&lc=en
Start the program and just follow the on-screen instructions.
I hope this will help.
Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
How do i get my phone to connect to the internet
You must have internet service, example an anything data plan. Then all you do is tap on the internet ball and it conects.
May 24, 2011 | HTC Desire Cell Phone
I can not connect to internet in my android mobile, how to set for internet setting, Please tell me.l.
You need to have either a wi-fi or 3g/4g connection and a browser installed on your phone. No other setup is required
Mar 16, 2011 | Google Android
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
Hello, i have just bought a Chinese copy of iphone 3g, but i am not sure which company has made this clone or what cpu is used inside... i bought this phone only because i wanted a cheap phone with wifi...
access point is a code of wi fi without it u cant to wi fi. some its shows connect but its connected its not only in mobile,but shows in pc also. its just because of internal settings. if u want to check ur mobile then u should go a place where wi fi is working like college etc. and u should know the code of wi fi. then set ur settings with code. good luck.
Dec 31, 2010 | Computers & Internet
Can you surf the web on an Apple iPhone without a Wi-Fi connection?
There are two nation-wide cell networks that allow you to browse the internet. The EDGE network (for original iPhone) and the 3G network (3G is faster, but not as widespread and can only be accessed through the iPhone 3G ). iPhone monthly plans include unlimited use of the internet, without using up your calling minutes.
If you can take advantage of a nearby wireless hub, you'll have much better speed than when you're on a cell-phone data network... but even without wireless, you can still browse, email, work and play via the EDGE or 3G cell-phone network.
Dec 12, 2010 | Apple iPhone 3G
Sony Ericsson P990i Cellular Phone Logo
105 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
