Question about Lexmark E340 Laser Printer
Lexmark E340 printer gave error " Replace Fotoconductor" I replaced the fotoconductor, but it still gives the same error
  • Wo0t-Wo0t Aug 28, 2008
  • 14 Answers
Reset Procedure(s) after putting in new Photoconductor kit
Resetting the Lexmark E340/342 (display type) machines
1) Turn the printer off
2) While still off, press and hold the SELECT and RETURN buttons.
3) Keep both buttons pressed, and turn the printer on. Continue to hold both until either “Performing self test” or “Config menu”
appears on the display.
4) Release the two buttons
5) RESET PC CNT should now show on the display. If it does not, press the left or right menu buttons until it does.
6) Press the SELECT button once. “Resetting PC Cnt Value” should show on the display.
7) When the display shows CONFIG MENU again, turn the printer off.
8) Turn the printer back on. (Do not hold any buttons down this time). The printer is reset.
You can confirm the counter was reset by printing a “menu settings page”.
Posted on Oct 24, 2008
Lanier 5622 says following output tray is full please remove paper. However it can be empty, half full, or completely full of paper and this error will not go away. Just replaced the photo conductor...
Hello!
Why did you change the fotoconductor Unit???? This part of the machine is to create the image.
Your problem is in the tray. Meaby a broken switch. Take out the all tray and look inside to see if there is same obstruction.
If you do not see anything i advise you to call a Tech.
Dont waste more money if you dont know what your doing. This is the best advise i can give you.
See you!
Aug 31, 2011 | Lanier 1205 Copier
Hola tengo una lexmark x340 presenta erro 84 remplazar fotoconductor
84 Replace Photoconductor
This message displays when the photoconductor is at the end of life.
The photoconductor must be replaced.
Jul 22, 2011 | Lexmark X342n All-In-One Laser Printer
I have an old ricoh aficio cl2000n. The printing is spotty at best. The colors seem to print though. I put in a new black toner cartridge and it still didn't clear up the problem. I emptied the...
I can give my opinion for free :) lol
You are saying that you have changed the Toner Bottle? Or the fotoconductor Unit (or drum Unit)?
Is your machine cleaned? What do you mean about spotty? Is it with dots?
From what you are saying i can only think that your drum unit Bk is faulty...
Well... i am not giving you much help... but is free right? lol
Change the fotoconductor and give the feedback
Jun 07, 2011 | Office Equipment & Supplies
I have a problem with my copy machine ref: gestetnel ref dsm416......error code SC500 I NEED YOUR HELP PLEASE!!! THANK YOR VERY MUCH
Ok! I found your model.
This code refers to a Main Motor Locked.
Almost certainly is an overload.
Try to change the Fotoconductor Unit.
There are been reported several problems with this machines. And the main reason is a defect in the Fotoconductor Unit.
If you still have a old one or eventually a new one try to change it and your problem is solved.
See you.
Apr 27, 2011 | Gestetner DSm615 Digital Imaging System
Error: 900 Service , RIP software e340 Printer
Turn the machine off unplug the power cord from it and leave disconnected for 10 mins.
Power back on if error still is present..
Power off again disconnect whatever cables are plugged in (Network cable/ USB) power back on if error error goes away with the cable(s) disconnected replace the usb/cat5 cable(s)
once that's done and the error is still present the system board will need to be replaced.
Oct 19, 2010 | Lexmark E340 Laser Printer
Reset fotoconductor lexmark e352dn
NOTE: Resetting the photoconductor counter/page counter should only be done whenever you replace the photoconductor unit.
Here's an article in the Lexmark website on how to reset the photoconductor page count. Just click on this link: http://bit.ly/9WAvUK. Hope this helps.
Aug 04, 2010 | Lexmark Lemark E352DN Laser Printer
My printer lexmark e352 shows an error code 84 replace fotoconductor unit. How to reset this error code
The above error code refers to :-
The Transfer drum has reached the end of it's life and must be replaced. May require service technician
Press "GO" to clear message and temporarily continue
Hope i helped you.
Thanks for using "Fixya".
Jun 23, 2009 | Lexmark E352dn Laser Printer
950 system board
Usually, at least on the Lexmark products I am most familiar with, a 950 error had occured when a printer had the systemboard replaced and the repair tech failed to update the new systemboard to reflect the correct information contained the printer's NVRAM.
From a software perspective, this should never accidently happen. Either the NVRAM on the printer is blown or the systemboard memory of the matching terms has been cleared.
Again, not a trivial endevor.
At this point, I'd suggest a service call to get the diagnostics run against the printer. You may have to replace the systemboard.
Don
May 25, 2009 | Lexmark E340 All-In-One Laser Printer
Fotoconductor fail
Hi Friend,
you can buy a replacement fuse and install it in your current photoconductor and reinsert and away you go. you say how, well i have carried out this proceedure twice already and still printing well.
my printer is also a c1900 i purchased my fuse on ebay for a fiver and it came with full instructions and photos on how to ( is is easy ) also inc was information on saving tonner which also works. since then i bought a replacement fuse at my local electrical retailer spares department and am currently using this one as i said i have changed fuses twice now. i hope this works if not contact me and i will copy that which i have.
many thanks
stevieboy
Oct 26, 2008 | Epson AcuLaser C1900 Printer
Lexmark E340 Laser Printer Logo
1,251 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
