Question about HP OfficeJet Pro k550 Printer
I cannot Print
My printer has new ink and paper, was only printing bits and pieces of a page yesterday then worked today it is printing nothing
  • Geego Nov 17, 2008
    same thing happened with me and I changed the heads and it worked for a couple months and back to its old ways of leaving out a line with every inch down it prints. The tech rep says the heads are bad again.
Buy a differently branded printer. I have had the K550 for two years and have had nothing but problems, frustration and time wasted.All in all I have had in working for a couple of months at most. Numerous printhead cleaning exercises and paper thrashed. A tortuous waste of hours of my time (and I mean hours) trying to get it up a going. Each time I left teh printer idel for a couple of weeks, the whole printhead cleaning circus began again. Read the reviews on other websites. This model is a complete dud. Nothing can be done to salvage it. If still under warranty ask for your money back. Otherwise bring it to a recycling centre,
Posted on Sep 05, 2008
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
I have installed new cartridges the colour prints perfect but the black is blurred with lies through it. i also found a small t shaped rubber piece about about 4mm x 6mm in the paper tray could this be the...
this rubber piece can be actually locket from printer rollers, but, returning to your smudgy printing
1. remove cartridges from the printer
2. check if there is bit of paper stuck anywhere in paper path, if so, remove
3. check if rollers on paper path are clean
4. touch bottom of the cartridge with absorbent tissue to check if ink is flowing through, if yes then insert cartridges back and print test page.
5. if cartridge do not allow inkflow, check what solvent is used (water, isopropyl alcohol or methylated spirit - this which do not cause precipitation is correct solvent), soak absorbent paper (tissue) with proper solvent and whipe head of the cartridge with it, 6. put drop of the solvent on golden knobs inside seats of the cartridges of the printer, allow it to soak in, wipe off with lint free tissue and put another drop of solvent in. allow soak in,
7. install cartridges back, print test page, it should start printing very weak and improving as it goes through the page (solvent will be printed first)
8. create "strip page" one line yellow, white space, one line cyan, white, magenta, white, black - print that page, this print will clean printheads and establish good inkflow.
all ink printers must print at least one page per week as to keep heads free of gum and ink in flow.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
States "Right Cartridge incorrect"
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
Printer keeps telling me I have a paper jam but theres nothing inside
Hello there
Mar 16, 2010 | Canon PIXMA iP3500 Printer
Dell 946 Printer
check on the series of the ink cartridge you got
946 all in one's has a lot of series for the cartridge
Sep 19, 2009 | Dell A940 All-In-One InkJet Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon MP 830 Print Issue
sounds like your print drivers on computer are corrupted..try this link for new ones(you may need to completely uninstall the old ones, first, though).
Mar 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printer will not work after installing a new cartridge (name brand)
I put the original almost empty cartridge in again and printed one page. Then I took it out and put in the new one, after wiping the contacts with a piece of plain paper. it worked!
Feb 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Will not print
Try using the 'clean cartridge' setting with your printer, this usually forces the ink through the installed cartridges.
Dec 11, 2007 | Dell 922 All-In-One InkJet Printer
HP OfficeJet Pro k550 Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
