Question about Pentax Optio 33LF Digital Camera
Optio 33LF LCD problem
Im having a problem with my new camera.Sometimes I will be cycling through some pictures I just took,and I can see them fine,then all of a sudden,my lcd goes blank and I get a message,"camera can not display image".Then all the pics I already looked at say this.Now,if I turn the camera off,fine.I turn it on,and it usually works fine again,but if I leave it on,then take 1 more pic,the red and green light by the optical viewfinder blinks back and forth,red,green,red,etc.and none of the buttons work,and the lights blink endlessly.The lcd is still working;no buttons work at all,and the only way to shut off the camera is to open the battery compartment,remove the batteries and reinstall them;then the camera usually works??
    Master:
  • 542 Answers
This often indicates a card error. Transfer all your images then format the card in the camera. If you still have the problem, try a different card. If you still have the problem then looks like you will have to send it in for repair.
Posted on Sep 08, 2005
SOURCE:
This camera accepts a 512 mb sd card maximum. If you try 1 GB or bigger, takes a couple of shots and freezes.
Mar 08, 2013 | Pentax Optio 33LF Digital Camera
When I put my 2gb Sandisk memory card in my pentax optio 33lf, it turns on, the lens goes out, it takes a photo and freezes. What is the problem? If I take the memory card out, it works fine?
My 33LF won't work with even a 1gb Memory Card. It freezez up as you describe.So far it seems happy enough with 512mb cards. A camera shop operator told me that the capacity of the card exceeds the capacity of the camera and it seems he was right.
Jan 08, 2011 | Pentax Optio 33LF Digital Camera
How do I upgrade the firmware on my Pentax Optio 33LF? Camera goes crazy. Does not recognize any more my SD card (2 Gb)and I'am afraid to loose the photos. I hope if I upgrade the firmware ( vers...
According to the Pentax web site, there is no firmware update available for the 33LF camera. As far as your pics are concerned, you can use a card reader to download them to your computer. Then, you can format the card in the camera and everything should be ok.
Jan 09, 2010 | Pentax Optio 33LF Digital Camera
My camera freezes
This camera supports only 512 mb sd card. If you use any bigger, it freezes. Tried with 1 gb and 2 gb and freezes, while 512 is just fine for the size of the pics of this baby.
Jul 22, 2009 | Pentax Optio 33LF Digital Camera
Pentax otio 33lf camera suddenly won't go
Try removing the card and see if it will turn on with just the internal memory--or try different memory card if you have one.
Had a somewhat similar problem with a new 1GB card when I shut camera off while it was still saving an image. Camera would come on, take a picture all by itself and freeze up. After using a couple of other cards it magically worked on the bad card
gmcn
Oct 14, 2007 | Pentax Optio 33LF Digital Camera
Why no sound?
I have a pentax optio 33lf, and indeed it has video, but with no sound. I have no idea why they chose not to build a mic in the camera bat the fact is thet it films, but with no sound. so don't even bother trying to find a solution because ther is none
Sep 26, 2007 | Pentax Optio 33LF Digital Camera
Won't turn on at all
My Optio 33LF gave the same "card not formatted" message and then shut down completely at a family party.  I took it to the Pentax Canada depot which is nearby and the technician said the main circuit board was gone.  A C$130 part + labour estimate = time for a new camera !
Sep 17, 2007 | Pentax Optio 33LF Digital Camera
256 Sandisk SD card problem with an Optio 33LF
Optio 33LF Firmware Upgrade Information & Instructions: This firmware corrects "camera freezing & cannot display images" issues with Sandisk & Black's 128MB & 256MB Secure Digital Cards. This problem is occurred because Sandisk changed the manufacturing location from the Philippine's to China during production of the Optio 33LF. They also change the electronic chip used the SD Card which caused a compatibility problems with Pentax, Minolta, Palm and other digital device manufacturers. In turn this also caused a problem with Black's SD Cards as they are manufactured by Sandisk. Therefore, we had to release a Firmware Upgrade for the Optio 33LF to correct compatibility issues with these SD Cards. HOW TO CHECK WHAT THE CURRENT FIRMWARE VERSION: Confirm the current firmware version by pushing and "HOLDING DOWN" the "Right Arrow & Right Zoom" button located at the back of the Optio 33LF. While continuing to hold the "Right Arrow & Right Zoom" button turn the POWER on the Optio 33LF. The current firmware version will be displayed on the LCD. If the firmware version reads "Current Version 01.01.05.04" then your cameras firmware is up to date. If you do not have the current version, then please refer to the information listed below. Please be sure to upgrade your camera. You can download the firmware from the following link. Please be sure to follow the instructions listed below. Firmware Download: http://www.pentax.ca/support/digitalsoftware/fwdc113p.elf Firmware Update Instructions: Please refer bellow to learn how to upgrade the firmware on the Optio 33LF. Should you have any problems please contact our customer service department. I have included our contact information bellow. PLEASE NOTE: 1. It is very important that the batteries do not deplete during the firmware upgrade as this will damage your camera. Therefore, please check your battery indicator prior to the firmware upgrade. FIRMWARE UPGRADE #1. Save the attached firmware "fwdc113p.elf" to your Desktop. #2. Put a Secure Digital Card in your Camera. #3. Format the Secure Digital Card to be sure that no other information remains on the Card. (Refer to page 86 of your Operating Manual) #4. From your Desktop right click on the firmware "fwdc113p.elf" and select "COPY" #5. Double Click on "My Computer" you should see your "REMOVABLE DISK" #6. Right Click on the "Removable Disk" and select "PASTE" Once the "fwdc113p.elf" file has been copied to the Secure Digital Card, be sure to properly disconnect your USB device if you are using Windows Me, 2000 or XP. For instructions on how to disconnect a USB device with Windows 2000, please refer to the Optio 33LF Operating Manual. Now that you have the Firmware on the Secure Digital Card. #1. Be sure the Secure Digital Card containing the Firmware Upgrade "fwdc113p.elf" is in the camera. #2. Be sure that your batteries are fully charged as you do not want the
Sep 08, 2005 | Pentax Optio 33LF Digital Camera
Pentax Optio 33LF Digital Camera Logo
104 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
