I have a samsung 40 inch tv series 4 and have just had sky fitted. I am now receiving a shadow on the picture and have been told by the sky engineer that there is a compatability problem. what advice can you give?
    Genius:
  • 2,920 Answers
Go over to a different company if sky wont work for you
Posted on Aug 28, 2008
32 inch LCD TV samsung series 5
If there is sound, no doubt, its signal input is OK. The problem must be to your Tv itself. If the LVDS cable, the cable that connects between the T'Con board and LCD panel have a loose contact, this type of faultcan occur. Re-seat this cable once, and check. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Hundred Thousand viewers cannot be wrong.
May 05, 2013 | Televison & Video
Sky remote control code for samsung ps43e45/49 tv
The code you are looking for is 1340. I have the same TV and my sky volume hasnt worked since I bought it, (9 months ago).. After spending an age on the SKY forum with no luck, I simply googled (Sky remote codes) and clicked on the 1st site, it's skyremotecodes.co.uk then Samsung 6000 series.... It told me the correct code and gave me clear instructions...... I hope this helps someone else.
Aug 17, 2012 | Samsung TV Remote Control
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Samsung LE40R
try to change the stantard from the channel setting menu(bg-dk etc.)
Jun 27, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Picture Flashing
I have a similar problem but my picture flashes black and white and the sound goes at the same. Also sometimes it will flash pink and blue. I've read elsewhere that the issue is a known problem with compatability between Samsung tv's and sky boxes. Apparently the box needs to be replaced but I'm unsure what type of box. I've read perhaps a PACE sky box could fix the problem. I think the best option would be to contact Samsung - that's what I'm going to do.
Feb 14, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Lcd clarity
they don't need time to settle down..
Nov 26, 2007 | Televison & Video
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Sony KDF-E50A10 50 inch LCD
your optical block requiers replacing.not a cheap job.around £600.00
Oct 03, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
