Pentax Optio S4 Digital Camera Logo
Anonymous Posted on Sep 08, 2005
S4 LCd problem
I have a friend who got an optio s4. Couple days ago her LCD screen started to have white stripes appear on them. You can no longer see the pictures clearly. The pics she takes are still ok when viewed on the computer. I don't know if there's something in the secret menu that could be the cause, or is the lcd completely broken and have to be sent to pentax now? Thanks for your help guys.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
157
Points
My screen wont let me do anything the screen comes up as card locked
1helpful
How do I troubleshoot a Galaxy S4 with new replacement LCD installed that displays one solid color?
there is something wrong in connecting pins in new display,check thoroughly,,,,,then factory reset by recovery options,,,,,should be ok,,,otherwise new screen display is defective
2answers
Cracked lcd pentax optio a20
someware you can detach the cable
A90 error Optio S4
Gerrit
So is jou probleem uitgesorteer ?
1helpful
2answers
Lense won't open
i had the same problem after letting the battery run very low. when i turn the power on, the camera beeps and turns off after a few seconds, the lens would not extend. i took it to a shop in china and they fixed it for about $25USD. i had the camera for 5 year now but it was worth $25 to get it fixed.
2answers
PENTAX OPTIO A30 BROKEN LCD
I've seen LCDs forA30 are sold via eBay.
In youtube there's a video of replacing the LCD in other Optio model.
I have the problem and I'm going to try it by myself. I'll let you know if it worked.
Optio s4 - help needed
You are probably in play mode and not in camera mode. Switch the camera back to camera mode (move the witch so its in the camera position- you will see a small camera icon) in order to take pictures.
2answers
File numbers problem in S4
I think you may have a defective camera - my S4 does not do this. Maybe you should reset the camera software by taking out the battery for a couple days and then try it again.
USB Connection problem Optio S4
have you turned the camera ON after connecting the cables? Next, does this USB port on the computer work with other USB devices such as memory sticks? My O555 has a USB socket that feels really "fragile" and I fear I will damage the socket with improper insertion (alignment seems touchy). I bought an external USB card reader and am really happy with that. You don't use up battery power transferring your files. Much better solution, IMO.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
