Question about Nintendo Wii Console
The sensor on our wii is broken - Nintendo Wii Console
    Problem Solver:
  • 12 Answers
If your wii is still in warranty, send it back to nintendo and they'll replace it for you.
If you don't you can just purchase a new one. They now have wireless one too!
Angela
Posted on Aug 29, 2008
My control for the wii will bring up the menu but the courser that you use to make selections does not appear.
Make sure the sensor bar is correctly plugged into the Wii, and that the Wii Remote has a clear path to the sensor bar. Move the Wii Remote around, as the positioning of the sensor bar may not be precise. If you are sure everything is how it should be, it may be that your sensor bar is damaged and/or broken. You may have to buy a new one.
Aug 20, 2011 | Nintendo Wii Console
Remotes wont show up on tv screen or ingage the game
Most likely a broken sensor, unplug it and try using two lit candles spaced apart the same length as the sensor, as they emit Infra Red light which is what the sensor does too, and what the Wii using to determine the controllers position, this can actually be used as a replacement for the sensor itself.
Jul 04, 2011 | Nintendo Wii Console
The cable to the movment sensor has been broken is it possible to get it repaired or replaced
yes they are online for less than £10, including places like ebay, just google replacement wii sensor
Jan 16, 2010 | Nintendo Wii Console
Wii not picking up signals from Wii remote
Try to re-sync your Wiimote by pressing the red button in the sd compartment on the Wii then the red button in the battery compartment on the Wiimote.
Dec 20, 2009 | Nintendo Wii Console
Wii Remote Turning Funtion Doesn't Work on Mario Kart
Your wii sensor bar probably went out, replace it. They sell wireless ones at wal-mart for $20. If you want to make absolute sure that the bar is broken, take a video camera and take a quick video of the wii bar while it's connected and the wii is on. If you see four little blue lights on each side then you're wii bar is ok, if any are gone it should be replaced. The fact that all the buttons are still working means that your wii is still communicating with remote using bluetooth, but since it's not sensing any motion, it probably means that the problem is sensor bar related.
Aug 25, 2009 | Nintendo Wii Console
What is the lifespan of the Wii remote? Having problems is it the remote or docking station. Have had it for two years is it time to replace?
Normally, the Wii remote will work properly unless dropped on the floor or banged against any hard surface. The Sensor connected to your Wii can sometimes end up dying because of normal use. This can be purchased for a mear 10 dollars at any Wal-Mart. If the sensor is not the problem, make sur that you are at the same level as your sensor when playing games. If you happen to be higher or lower, your Wii remote may end up moving unvolantarily around for no reason. The Wii remote is sturdy and has never broken up for me for the past 2 ½ years. Does the problem arise only when you use the docking station battery? If so, the battery would be the problem. I have stopped using this battery because of problems like these. I would recommend recharable Ni-hM batteries instead.
Hope this helps,
Regards
Jul 25, 2009 | Intec Charge Station w/ Rechargeable...
No connection from remote to screen
Your sensor bar is definitely burned out, you can get a new wireless one at wal-mart for $20. Often wii sensor bars burn out because people put it directly on the tv instead of using the stand, the tv gets hot and the LED lights in the sensor bar burn out. If you want make sure that it's the sensor bar that's broken, get a video camera and video tape the sensor bar while it's plugged in and the wii is on, if you can't see four LED lights on each side then it's broken.
Jun 14, 2009 | Nintendo Wii Console
Wii remote not working.
Get some regular alkaline AA batteries and try your Wii Remote using them -- the blue lights on the Wii remote should light up and register with the Wii console (this is via wireless / bluetooth) -- As for the sensor bar, it is really only an infra red emitter - so if you have it properly connected to your Wii, the Wii Remote (with working batteries) can sense where it is by "seeing" the lights emitted from your sensor bar.
If the alkaline batteries work - You may need to get some new NiMH AA batteries to use in your charger - changers are usually third party devices; Nintendo does not ship charging stations with the Wii.
If the Wii remote appears to be working (blue lights and all) and your sensor bar is properly connected, you may have a dirty or damaged IR port. First clean the top of the Wii remote, just to make sure. If it still does not work, borrow a friends Wii Remote and check to see if it works with your system. If you do everything above and your Wii remote does not work while a seperate one does, the problem is most likely a broken Wii remote.
Jan 01, 2009 | Nintendo Wii Console
Wii remote is inverted???
Broken Wiimote. Better buy a new one.
Mar 20, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
16 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
