Question about Zoom H4 Handy Recorder
H4 randomly stops recording on cubase le
Using the H4 as an interface to record with Cubase LE, the track suddenly freezes after ten to fifeen seconds or so and then continues in play mode. I've tried batteries in and out, different USB ports etc. Is there a solution? Is it a firmware problem?
I use Windows XP on the computer.
I may possibly have solved this. I didn't realise that when I log off from Cubase, the ASIO driver returns to the Multimedia ASIO driver, which seems to be the default setting.
Every time I want to record with the Zoom H4 in future I'll need to reconfigure the ASIO driver to the H4 one.
I thought once I'd set the driver, it would remain there every time Cubase booted up. Apparently not.
Posted on Aug 31, 2008
How do i get levels from my g track mic im using cubase le 5 i only get one side level how do i fix this issue?
The mic is only on the Left channel, and instrument input is on the Right channel. So in Cubase you need to select only the Left channel in your first track, and then only the Right channel in your second track, and then you can record Vocals and Instrument at the same time on 2 different tracks.
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
Getting mic setup thru cubase le 4
Make sure phantom power is enabled on the Tascam audio interface and you must enable the input in cubase that corresponds with the interface input on the track you are trying to record to.
Sep 28, 2009 | Tascam US-144 Sound Card
File import in 4-track mode impossible
Convert the audio to Mono WAV (16Bit, 44.1KHz). This can be done by using Cubase(Hope you got Cubase LE with Zoom). In an empty project import the audio, then mark the whole track using the Draw tool and then got to File->Export. Here select the above options and export. Import this file into Zoom H4 either by copying directly into the memory card or through connecting the Zoom to computer ( I copy it directly into the memory card's STEREO folder). Now if you import it to any project, it will appear there. You can now use Zoom H4 as a Karaoke device!! Anyway, sad that Zoom H4 doesn't support stereo tracks in the 4Track mode.
Aug 14, 2009 | Zoom H4 Handy Recorder
Connect to PC does not work
You need to upgrade the H4  firmware from Zoom website
You will need an external SD card reader.
Good Luck
May 06, 2009 | Zoom H4 Handy Recorder
Transfering music from the H4 handy recorder to the pc.
Make the instalation of cubase LE that come when you buying the Zoom H4.When you instaled this,the driver H4 must appear in the sound/device properties.I hope you can solve
Apr 06, 2008 | Zoom H4 Handy Recorder
Distortion with Zoom H4 as Audio I/O to computer
try using the power pack instead of batteries. Be sure to remove the batteries before using power pack, you can wreck the machine if you do not remove batteries. NEVER use the H4 on power pack while there is batteries inside.
Mar 31, 2008 | Zoom H4 Handy Recorder
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Burn CDs from Tascam US-122L
The answer is yes, but it may not work as simply as you think. You can't just save your Cubase file / mix and then send it to your recorder. You'll want to render down the song you have to one stereo .wav file and send that to burner as a wav file. (That's the quick way). Another option is to render each file you have seperately so acoustic guitar, bass, vocal, etc are all seperate tracks. So the answer is yes, a .wav file is the format for audio cds. You'll record your seperate tracks and then you'll have to mix down, render, or export them when you are done. In Cubase, use "export".
Feb 07, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Zoom H4 Handy Recorder Logo
450 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
