Question about HP DeskJet F380 All-In-One Printer
Alignment not good - HP DeskJet F380 All-In-One Printer
    Novelist:
    Scholar:
  • 111 Answers
HP has a page on their website that tells you how to align your cartridges:
Aligning Print Cartridges
Good luck.
Posted on Oct 07, 2008
How to change camber bushing on 2003 e 250 van
You need to take it to alignment shop with a good alignment tech. Because there are measurements they need to decide if you need a sleeve. So you must find a real good alignment tech that knows how to use it. The camber change is required to have the optimum settings and must be added or subtracted from the amount of camber on production camber adjuster sleeve. There's a possibility that the front end parts will be damage from impact or in just plain wear and tear and it's impossible to knock a vehicle out of alignment. You may have the best equipment in the world but it's no good if nobody knows how to use it.
Oct 18, 2014 | Cars & Trucks
Tire alignment
Yes you need the caster and camber kits. The advice is good.
May 21, 2013 | Lincoln Navigator Cars & Trucks
Manual for TwinStar 1000mm focal length telescope and equatorial mount
Equatorial mounts need to be polar aligned to work correctly. Once the scope is polar aligned (see manual or look online for polar alignment instructions), turn on the RA motor. Loosen your RA and DEC locks and find a object you want to view, The motor should keep the object in view for a while (depends on how good the motor tracks and how good your polar alignment is.) Spending 10 minutes polar alignment on my C8 keeps the object in view for about an hour without adjustment.
Dec 16, 2011 | Celestron Optics
I have a Powercurve 1800 electric snow thrower. Model 38025 , serial # 280014353. It has givenb me good service until this week now it is tearing up the diver belt # 73-0160. I cannot get 1 hour of...
Likely it is an alignment problem. Look over the machine carefully and align your vision with a pulley. Look at the other pulley ( s ) to see if they are in alignment. It could also be a mount for one of the components or pulleys that is flexing under load, knocking things out of alignment. Install new belt and rev the motor sharply as you watch the pulleys to see what is moving out of alignment. If you don't see any alignment issues, check over the belts route to see if something is moving in to the path of the belt and scoring or grooving the belt. Good luck - this will require some patience and good fortune!!
Dec 16, 2010 | Garden
Meade LX200GPS The scope does not complete the 'Auto Alignment'
Once the scope has taken a GPS fix and knows TIME, and SITE, and you do a two star alignment your alignment stars overide any automatic alignment issues.
You could turn off the GPS put in Time, Date, and Site, do a two star alignment and everything would be fine. Centering the alignment stars is the "trick". Apparently the scope also finds NORTH OK, or the alignment stars would be way off. Since you pre-level the tripod already the software can FAIL on "tilt" and you still get good gotos.
I would not worry about it, especially since your gotos seem perfectly fine.
May 28, 2010 | Meade LX200GPS Telescope
Left wheel bearing replaced no alignment done.
the car does not need to be aligned after a wheel bearing replacement. it is a good idea to get this done every 6 months depending on driving habits though. good maintenance.
Feb 18, 2010 | 2004 Mazda 6
What is E7 on the canon mp160, and not working anyway..
When the head alignment sheet was not filled in properly Printer show E7.
  • Confirm circles on head alignment sheet are filled in properly MP160
Head Alignment Sheet The head alignment sheet was not filled in properly.Confirm the circles were filled in as follows:
Good example:
Bad examples:
If more than one circle is filled in, reprint the Head Alignment Sheet.
Print Head Alignment
  1. Ensure that the printer is powered on and open the paper output tray. (Confirm that the paper thickness lever is set to the left.)
  2. Load a sheet of A4 or Letter-sized plain paper in the auto sheet feeder (or ASF).
  3. Press the <Maintenance> button several times until [P] is displayed in the LED.
  4. Press the <Black> or <Color> button. The machine prints the head alignment sheet.
  5. From each group, select the pattern which has the least visible streak.
    Example of the pattern with the least visible vertical streak
    Example of the pattern with the most visible vertical streak
  6. Pencil in the circles on the left side of the selected pattern, using a dark pencil.
    < 1 > Good example
    < 2 > Bad example: Checkmark
    < 3 > Bad example: Line only
    < 4 > Bad example: Not dark enough
  7. Open the document cover and load the head alignment sheet on the platen glass.
    Note: - Place the printed side down.- Align the sheet with the alignment mark (shown by the arrow) on the lower right corner of the platen glass.
    05sj00115_06.gif Alignment Mark
  8. Close the document cover gently.
  9. Confirm that U is displayed in the LED.
    If U is not displayed, press the <Maintenance> button several times until [U] is displayed in the LED.
  10. Press the Black or Color button.
  11. The machine scans the head alignment sheet and aligns the print head automatically.
Feb 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Message: "Press Enter to align cartridges" When I do that it starts to do the alignment, then stops and repeats the message. It also won't print.
My thought is that one or both of your cartridges are no good. The printer will not print until it knows the alignment is good.
Nov 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Front left tire is towed inward could this be a tie rod problem?
yes, its a tie rod problem. Bring your car to a shop with computerized wheel alignment tools and have your wheel aligned
Jun 20, 2009 | 1993 Saturn SL2
CF card
Hi, try it to align but be sure remove battery before aligning , look a small two niddle and align it bending to make good alignment.
Jan 08, 2008 | Canon PowerShot A75 Digital Camera
HP DeskJet F380 All-In-One Printer Logo
227 people viewed this question
Seeker5211
Seeker5211
