Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Simple-Tech Pininfarina 380GB Failure
This is my second drive in less than a year. The first one failed approx 3 mos after purchase, and was replaced under warranty. Now, the second one has apparently failed. Although it powers up ok, it is no longer recognized by my WinXP computer. It also is VERY warm to the touch.
It had been working fine through a USB hub. Removing the hub and plugging the drive directly into the computer does not have any affect on access.
It still shows up in the device manager and is reported to be operating correctly, but does not show up as a drive in "My Computer."
One other external drive - another brand, and several years old - continues to work fine through the hub.
Based on my readings of the post here it appears that SimpleTech, at least as far as this particular model of drive is concerned, is selling a product with a short service life.
Jeigh
  • rnordmann Nov 19, 2008
    I have the same problem. Has anyone tried to go to an computer tech company to have them try to extract the files to a disc?
I junked the drive...
Posted on Aug 29, 2008
My SimpleTech SimpleDrive Pininfarina 500GB... stopped working
open the hard disk casing remove the drive check it on some other casing
May 06, 2014 | SimpleTech SimpleDrive Pininfarina 500GB...
Simpletech 250 GB Pininfarina was knocked on the floor
oped it, maybe loose cables or connections. or the worst case, a faulty hd. ticking sound means bad drive, cannot read disks. retrieve data? the better chance will be a recover technician, dont try anything else, will turn a worst problem.
Jun 02, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Hi where i can get the dirver for simple tech simpledrive pininfarina 320gb external usb 2.0 harda drive- blue? please i need one dirver to recognize my usb where i can get it?
If your version of windows dosn't have the driver, there is that possibility that your drive is not supported.
Two things I want you to do ... check the Microsoft Hardware compatability list at http://www.microsoft.com/whdc/hcl/default.mspx
Visit the simpletec web site ... http://www.simpletech.com/support/ and see if they offer something.
If your device is not on the windows compatability list you are probably out of luck unless the manufacturer offers something for it.
I have presumed you are running windows ... since you dont say otherwise.
May 30, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
COMPUTER DOES NOT RECOGNIZED SIMPLETECH EXTERNAL HD
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Jul 09, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a 60 GB simpletech external hard drive. I
Try to hook it up to another computer and see if it works there. This will tell you if the device is failing. If you have found that it failed please see about replacing the power adapter. If still no live the device has failed and needs replacement.
Thanks, Frank Z.
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 24, 2009 | SimpleTech Pininfarina 60GB External USB...
500Gb SimpleTech Ext Drive No Power
Hello.
It sounds like you might have a problem with the power supply.
I have seen MANY external hard drives with failing power supplies. Take it to the store you purchased it from for a check up, it should still be under warrantee if its only 3 months old.
Good Luck!
Jun 17, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Simple Tech SP U25/60 external hard drive
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Feb 24, 2009 | SimpleTech Pininfarina 80GB External USB...
MYBOOK PREMIUM HD Delayed write failure?
Most likely the drive has bad sectors. You should get it replaced it and don't store any valuable data on it.
Jul 29, 2008 | Western Digital My Book Premium ES...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
134 people viewed this question
Top SimpleTech Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
