Question about Toshiba e800 Pocket PC
E800 with bluetooth card 2
Got the e800 pda and the toshiba bluetooth sd card 2. i instaleld the stacks... didnt work... even installed the socket drivers... didnt work.... any ideas why this product isnt working with my pda?
    Master:
  • 903 Answers
It is very strange. The only thing that I can recommend you is to check Toshiba Bluetooth download page and check for stack update or FAQ page. Check it on http://aps.toshiba-tro.de/bluetooth/
Posted on Sep 08, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Connect to internet?
This answer assumes that the reader is already using their SD slot and wish to use another way to connect to the internet. I'm going to show you how to connect a USB Bluetooth dongle using the Toshiba e350 USB host cable. After that you can choose to share a computer internet connection via ActiveSync/WMDC or use BT DUN and a wireless phone with existing internet plan.
Windows based PC software (only needed for ActiveSync based internet sharing):
ActiveSync or WMDC
Toshiba PC Bluetooth stack 7.10.04 (or latest version for your operating system, I'm using Windows 7)
PC Hardware:
Super Mini Bluetooth 2.0 Adapter Dongle (mine was VID 0A12 PID 0001 Broadcom BCM2045 "CSR" based)
WM2003 PPC software:
Zeno USB Host Drivers v6.0a
Toshiba PDA Bluetooth stack 4.01 (filename bltstk-401-en.zip)
WM2003 registry editor (TaskMgrv2.9_WM2003SE.zip is a free task manager and registry editor, very cool)
Opera Mobile 8.65 (optional)
WM2003 PPC Hardware:
Toshiba USB host cable
2 or 4Gig SD card (for e350)
I'm going to target a Windows 7 PC with USB Bluetooth adapter, Windows Mobile Device Cener (WMDC), and an already partnered and synced Toshiba e350/355. The reader should already have a 2Gig SD card in the e350; remember WM2003 doesn't support SDHC. Any software to be installed onto the device should be done through ActiveSync Add/Remove and should not be installed to the default internal memory, but instead to the SD card.
Let's start by loading the e350 software. Install the Zeno Host drivers, followed by the Toshiba 4.01 stack. There is a newer version of this stack but it didn't work for me, so find the older bltstk-401-en.zip. The registry editor is needed for ActiveSync internet connection sharing but optional for BlueTooth Dial-up Networking (BT DUN). I'd recommend installing Opera Mobile as well. Be sure to press the reset button on the back of the e350 when done. You may now connect the USB host cable with Bluetooth adapter.
On the Windows PC connect your Bluetooth adapter and install the Toshiba PC bluetooth stack. Power up the e350 and, after a short time, there should be a wireless icon in the lower right hand corner of the main window. Back to the Windows PC, double click the Bluetooth icon in the task tray and you should be prompted to create a new connection. After awhile it should recognize your Pocket PC. If at any time you are prompted to insert a password for secure connectivity, write down a number (preferably 8 or more digits) and type it in. It will probably ask on the Windows PC first but once you continue immediately check your e350 since it will now prompt for the same password. Once it has been entered in both devices they are now "paired".
Tap the wireless icon on Pocket PC then Bluetooth Settings. Tap the magnifying glass to search for connections, your PC should already be listed as a remote device. Tap and hold over the name of your PC in the upper portion of the window and select Update Service. At least one COM port should be listed in the lower window. Tap and hold over it's name, then tap connection registration.
On the Windows PC open WMDC and select Connection Settings. Change the "Allow connections to one of the following:" drop down to the COM port listed on your device and be sure it's checked. The other settings should be default.
On the Pocket PC tap ok to close Bluetooth settings then tap Start > Programs > Bluetooth Folder > Bluetooth Connection. This will initiate an ActiveSync session and, if everything has gone well, it should connect, perform a sync then immediately disconnect. I have a problem with the immediately disconnect part, that's where the registry editor comes in. Using your preferred registry editor locate the HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\Bluetooth\DeviceProperty\Mode\ActiveSync\AutoDisconnect key. It's default value shoule be 1 but we want to change it to 0 thereby preventing ActiveSync from disconnecting after it sucessfully syncs.
With that done you'll probably need to reset the e350 again. At this point, because ActiveSync is set to share the computer internet connection by default, the next time you connect you should have internet access. Open your preferred web browser and check. When you are done with the internet, tap Start > ActiveSync and the Stop button. In Windows 7 as long as I'm connected I can see the Pocket PC in Windows Explorer as if it were an external drive. This makes it very easy to copy files back and forth wirelessly. Initially I set up a bridged PAN connection but, to be honest, ActiveSync works much better all around.
For BT DUN you'll need a properly configured and enabled Cell Phone with bluetooth DUN capabilities. Simply make the phone "visible" and search for it as you did the Windows PC. Pair with the phone, Update Service and register Dial-Up Networking. Tap Start > Settings > Connections tab > Connections > Add a new modem connection (Tasks tab). Enter a name for the connection and choose Bluetooth Card as the modem, then set the dial-up number, User Name, and Password from your Cell Provider. On the Advanced tab (next to Tasks tab) you may want to tap Select Networks to verify "Programs that automatically connect to the Internet should connect using:" My ISP.
You can set up ActiveSync Internet sharing along side BT DUN. When ActiveSync is connected it will automatically be the source internet connection. When disconnected, the e350 will automatically attempt to use the BT DUN connection instead.
Why not use the default Microsoft BT stack on the PC? It doesn't publish any real services, just a COM port that I never got to work. The Toshiba BT stack does have a 30 day warning so you might need to fix that.
For me the total cost of setup was about $30. The host cable was $15, the SD card $10, and the USB BT dongles were $2 apiece.
Nov 03, 2009 | Toshiba e350 Pocket PC
Music files
I have e800 and there is no problem with mp3 music files. You can save it on PDA directly or even on SD card. The only thing is sound quality. The PDA speaker is not the best one. If you want you can use stereo headphone.
Sep 11, 2005 | Toshiba e350 Pocket PC
E310 and GPS
Before you buy the GPS for your PDA please be careful if the GPS manufacturer guaranteed the functionality with your PDA. I have e800 and I plan to buy the GPS for my unit. Unfortunately at the moment I have no information which one you should you use. You should have a look at the following document, to see how to setup a BT connection to your BT -GPS device. http://aps.toshiba-tro.de/bluetooth/redirect.php?page=pages/howto.html http://aps.toshiba-tro.de/bluetooth/pages/howto/How_to_use_a_Bluetooth_GPS_Receiver_v002.zip
Sep 11, 2005 | Toshiba e310 Pocket PC
Internet access via bluetooth
I don't have a PDA, but I'm working much with Bluetooth in my Toshiba Notebook. So I found a interesting link from Toshiba about Bluetooth. Perhaps it helps you! http://aps.toshiba-tro.de/bluetooth/
Sep 08, 2005 | Toshiba e800 Pocket PC
Bluetooth malfunction
the only thing you can try to "reinstall" is the PC Bluetooth Stack. Goto "http://eu.computers.toshiba-europe.com" , search for "support & downloads", now click on "downloads". Choose your PDA Model and download the available stack.
Problems with e800BT and com ports
I use an e830 with a Holux GR230 without having any problems. The e830 uses already the latest stack from Toshiba so no need to upgrade. For the e800, hm depends on what kind of BT SD card you use, meanwhile Toshiba sells the BT SD3 card. Anyway, I would recommend to use the latest BT stack from Toshiba for your Toshiba BT SD card.
E800 wifi with sd bluetooth card with emtec crux11/btgps
Many people here have reported issues with the default Windows Mobile 2003 Bluetooth stack (basically, it just doesn't work). What may be happening in your configuration is that the CF card software is installing another Bluetooth stack (e.g. Widcomm's). This would explain why everything works thereafter.
Rom Update
As far as I know there is a big difference between Japanese and European images and you can not compare them at all. If the Japanese image has a bug or if there is some problem that can be corrected with a new update that doesn’t mean that European units needs an update too. Many of your questions are not completely understandable and I can just give you an advice to use a new BT driver (question 5). I have also 1 GB SD card and I use it with my e800 without any problems. At the beginning I thought that it will be read slowly but I am very satisfied with reading/writing speed.
Sep 08, 2005 | Toshiba e830 Pocket PC
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
Toshiba e800 Pocket PC Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
