Question about HP iPAQ RX3715 Pocket PC
Hard reset issue
I have tried to perfomr a hard reset on my iPAQ (button 1 and 4 and press reset button with stylus). The reset works up to the end on the progress bar, then it just stops, I cannot power off or anything. What can I do to get this to work? Thanks,
  • MiriamJm Dec 09, 2007
    you see, i have sorta the same problem. i can reset it, ( pressing the 1 and 4 buttons and holding the stylist in the reset button for a few seconds) and then when i get to the start up bar. it locks it self and i cant unlock it. so then i have to reset it again, i cant get to any of my files, etc.
    Miriam M.
Remove battery to switch off, then try the hard reset.
Posted on May 19, 2007
Update ROM.
Posted on Jan 27, 2007
Ipaq 111 hard reset
Soft reset Perform a soft reset
A soft reset stops all running applications, but does not erase any programs or saved data.
NOTE: Be sure to close all running applications before performing a soft reset.
To perform a soft reset:
1. Locate the recessed Reset button on the HP iPAQ.
2. Use the stylus to lightly press the Reset button.
Hard reset
To perform a hard reset and return the HP iPAQ to factory settings:
Press Win + OK + Record together.
While doing that, press reset button and hold for 3-4 seconds.
Release reset.
Release buttons.
NOTE: Do not release the buttons until CLEAN REBOOT appears on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | HP iPAQ 111 Classic Pocket PC
I forget my password....so how should i break it?
the password can not be broken, but you can perform a hard reset that wipes the device clean including the password. all content is lost.
1. Press and hold the lower left and lower right buttons.
2. Press the Reset button on the bottom of the iPAQ Pocket PC
with the stylus.
3. Hold all buttons until the displayed image begins to fade
(approximately four seconds).
4. Release the program buttons and stylus.
You can verify a full reset by pressing the power button. If the
iPAQ Pocket PC has been fully reset, it will not turn on.
5. Reactivate the battery by doing one of the following:
Connecting the iPAQ Pocket PC to AC power
Pressing the Reset button with the stylus
Nov 06, 2010 | HP iPAQ H5450 Pocket PC
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
My ipaq hx 2415 will not go past the ipaq screen reset screen
Have you tried a hard reset (deletes everything)
2. While holding down these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
Mar 18, 2009 | HP iPAQ HX2415 Pocket PC
Rx5915
I got this info from HP website..
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until
the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the
Reset button.
The HP iPAQ restarts and powers on
It doesn't mention a password. I also have an HP Ipaq and don't need a password to hard reset. Good luck. If this helps you plz rate this. Thank you kindly.
Jan 31, 2009 | HP iPAQ rx5915
Hp ipaq hw6915
Try a Reset....
Performing a Clean Reset will help
A clean reset clears all user-installed settings, programs, and data, and restores
your HP iPAQ to factory settings.
To perform a clean reset and return your HP iPAQ to factory settings:
1.Press and hold the Answer/Send, Power, and End Call buttons.
2.While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ until the device restarts.
3.When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ restarts and powers on.
Thanks
Nov 03, 2008 | HP iPAQ hw6915 Smartphone
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
HP iPAQ 6365
Please perform following steps.
Take the back up of data.
Clean the battery.
Hardware reset.
Perform the Hard reset
1. Press and hold the Answer/Send, Power, and End Call buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
Sep 12, 2006 | HP iPAQ h6315/h6365 Pocket PC
Ipaq RX3715 hard reset
hard reset: Button 1 and 4 and press reset button with stylus
Jul 11, 2006 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
171 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
