Question about Elo Entuitive 3000 Series 1747L (Black) 17" LCD Monitor
1747L I need the main board PTB-1195 66832119500-01 for this ELO ET1747L touchscreen monitor. Do you know where I can find these boards?
I got one ....pirate_4200@yahoo
Posted on Jan 02, 2009
Touchscreen display elo flickering
Turn down the brightness on the monitor, if it works it will be a short term fix, the problem is in the inverter transformer or capacitors in the power supply board.
Apr 03, 2012 | Tyco Electronics ELO Parts Touchscreen...
The touchscreen is not working, it's seems that the USB port is loose. Where can I find a replacement part or can it be repaired?
The USB port is soldered to the driver board in the monitor. If it is loose then either the jack is broken and will need to be replaced or the jack is pulled from the solder on the board and will need to be resoldered. Hopefully the board was not damaged. The ELO monitors are a pain to open the case on and you will need to know how to solder to replace the jack. If you don't normally do electronics repair then in this case it would be best to find a repair technician than can do the work for you. As long as the board itself is not damaged then this type repair should not run over about $50 (parts and labor) plus shipping. Here is a link to a service site that can do the work for you.
http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
BuddyMc
Aug 16, 2011 | Elo 1515L (Grey) (Dark Gray) 15" LCD...
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
ELo touch screens not responding to the touch?
is the screen worn? you might need to replace the touchscreen glass
Aug 31, 2009 | Elo 15" Touch Monitor
My ELO touchscreen stays black, but the beep works
backlight problem you need to replace the backlight
Aug 13, 2008 | Elotouch 17" LCD Monitor
Blank screen
elo touch screen ET1925L -7SWA1 i get no picture on the screen but i hear sounds coming ou the back of theespeakers.. could it be the inverter?? help
Oct 24, 2007 | Elotouch 17" LCD Monitor
Elo Entuitive 3000 Series 1747L (Black) 17" LCD Monitor Logo
247 people viewed this question
Top Elo Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Sam DeGonia
Level 1 Expert
shahid_ptv
Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
