Question about Pioneer Audio Players & Recorders
My pioneer sx-1900 wont turn on,fuses and switch are ok and have read that it MIGHT be the output transistors but dont know what or where they are so i can source and replace them,problem is i cant get hold of manuals/diagrams to carry out the repairs. PLEASE help me,i am not an electronics tech but work on EFI cars day in day out so have a BASIC knowledge of electronic diagnosis/repair. thanking you Tim Baldwin
  • 883 Answers
SOURCE: Protect message when I turn on the receiver
call 800-488-7669 for tech support
Posted on May 27, 2007
SOURCE: onkyo tx-sv535
you tried reset on front panel? you hold down video 1 and then also press power off. the panel says "clear", then start up again.
Posted on Feb 08, 2008
  • 3 Answers
SOURCE: COBY TFDVD5605 Portable DVD Player repair tips
all potable dvd player work on 9V through cig lighter in your car adopters comes in three diffrent sizes.
Posted on Jul 20, 2008
ysastek
  • 28 Answers
SOURCE: MOTHERBOARD REPAIR
First off, is the motherboard actually the problem? If your motherboard has failed, the screen may come on and you may have some sort of raster (brightness) but thats as far as you get. Power supply failure is (in my experience) more common than mother board failures (usually) and may exhibit the same symtoms. Also a bad battery on the motherboard will cause funky things to happen on boot. (clock not right/failure to recgonize hard drives, etc). If you are certain a motherboard is a fault you should replace it ( unless you are VERY fluent in soldering/desoldering surface mounted components and component level repair and have a solid understaning of digital and D.C. circuits) More often than not, replacing the entier motherboard is cheaper and less of a hassle.
Posted on Sep 13, 2008
SOURCE: NAD 7155 with one speaker channel not working
In my case, if I push in on the balance knob, I can get the channel that quits to work for a while.
This leads me to believe that the pot is dirty as opposed to a circuit or component failure.
A couple of years ago, I sprayed circuit cleaner into the pot as best I could and the problem disappeared but, it has returned.
My next attempt will be with one of the newer cleaner/lubricators that are available now.
I don't know if this will solve your problem but, it might be worth a try.
BTW, getting access to the volume/balance pots takes some doing. As long as you are there treat both pots.
Greydog(1)
G
Posted on Sep 22, 2008
Blowing fuse
Your output transistors are shorted and need to be looked at by a tech.
Apr 04, 2014 | Pioneer SX-205 Receiver
Pioneer sx315 receiver shut off after being cranked up for a while and wont turn back on checked fuse its good. power button seems to work clicks when turned on and off
If the power to the outlet is still good, then I would suspect the power amp IC or output transistors are shorted, keeping the power from coming on. It's also possible that one or more of your speakers are bad feeding back to the receivers output connectors, especially if you were running speakers with a different power rating or impedance that your set is designed for. Hope this helps.
Jul 10, 2011 | Pioneer SX-315
Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Dec 17, 2009 | Audio Players & Recorders
The transistor of my pioneer sx-203.i remove my power transistor so that i can replace but it lost...i dont know the code of the power transistor or the main transistor.
Tell me the board no or exactly where it is located or there will be a number like T XX for denoting the sequence no of that transistor
i have a good one working now with me
if you have users manual please send for me
Dennis
Apr 26, 2009 | Pioneer Audio Players & Recorders
Pioneer SX-9000 Receiver Nothing out of the left channel no sound
Could be as simple as a bad connection at one of the regulators or as complex as a blown channel. These are good units that are worth the repair cost. Where are you located?
Dan
Jan 30, 2009 | Pioneer SX-205 Receiver
Pioneer SX-950
Speaker Relay Output Switch was a common problem with most SX models of the 70's. It's the switch you hear click on after about 4 seconds of power switch being turned on. It's still avail. thru Pioneer parts for around $45.
Jul 28, 2008 | Pioneer AVIC-S1 GPS Receiver
Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Mar 07, 2008 | Audio Players & Recorders
Pioneer m-770 will not turn on
you probably have a short in the circuit some where. you need to replace the transistor and look at all the solder joints to make sure there not damaged or cracked. i have the same amplifier and i replaced the fuse several times and it blew every time up until the last time when the 4 of the power output transistors blew. what ever you do do not try and power it on till you do all the things i told you or you will have sparks and fire. my mistake cost me my amplifier. but might help you get yours repaired
Dec 24, 2007 | Audio Players & Recorders
Pioneer SX-203
a little bit foolish thing: see if you have both the speaker channels (A and B) down. if you have both down it doesn't work - didn't for me.. and obviously make sure you have the right letter down - same outpout as your boxes
Dec 06, 2007 | Pioneer SX-205 Receiver
177 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
