Question about Dishwashers
Brushes on washing machine need changing - Dishwashers
    President:
  • 1,462 Answers
Is this a statement or a question? if brushes need changing then get into gear and change them
Posted on Aug 28, 2008
How to change carbon brushes on wt960 washing machine
Most washing machine motors do not have brushes.
Feb 25, 2015 | Washing Machines
Why won't the drum spin on my washing machine and can I fix it myself
Very likely the brushes are worn, these are located either side of the motor. if you are able to take the motor off the machine but don't know where the brushes are, take the motor to your local repairer who will probably change the brushes for you at a small fee plus brushes. if you are able to identify the brushes and can take them off, the carbon inside the brush holder should be no less than half and inch long. If its less they are probably worn out. get new ones and replace. be careful the carbon brush is very brittle and will break easily. I can't be more specific on changing the brushes as each machine is different.
Oct 17, 2014 | Tricity Bendix Biw125w Washing Machine...
Where are the brushes located on an asko washing machine ??? I'm fairly handy, can I replace myself ???
hi, I used to fix asko's when I was as work and found the motor brushes really easy to fix on the older machines. I found it best to drop the motor down and change the brushes at the back of the motor on the bench. hope this helps. remember to change both brushes though.
Mar 25, 2013 | Asko Washing Machines
I want to change the brushes on my bosch washing machine
Some bosch you can buy cabons brush on its own cost £10/£25......Some models you need to fit half motor with brushes located within, cost of parts £60 approx from espares.co.uk
Feb 23, 2010 | Bosch Classixx WFL 2066 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
How do i change the brushes on my wma35 hotpoint washing machine so that it'll spin?
unplug first then remove top cover motor should be there remove motor 2 bolts then u can change brushes
Jun 30, 2009 | Hotpoint WMA30 Front Load Washer
Changing the brushes on a beko washing machine
Its been a while since I changed beko but here goes.......... Put the machine on its side (soapbox side down, This prevents excess water from the soapbox dribbling into the PCB and creating a further problem). There is an opening at the bottom of the machine in which you will see the motor. On each side of the motor will be the brushes each with a connecting spay-tag, gently take of the spay tag with long nose pliers (not grabbing the wire) and change the brush. VERY IMPORTANT.....each brush is angled and it is important you replace the correct brush eg. left hand brush to left hand etc. or else when you goto wash the next time you will simply hear a bang and have to price a new motor. I highly recommend when you take each brush off do it slowly noting its angle and replace the new one at the same angle. Wfen done replace the spay tag. I am presuming you know to do this when the machine is fully powered off and plugged out. Happy Fixing.
May 07, 2009 | Washing Machines
How many brushes do i need for a beko wma 641 w washing machine
hi from uk all you need to do is ask for set of motor brushes for your machine type/model and these come in a pack usually two brushes ? in uk they cost approx £5 to £7 a pack ? and can be obtained from most domestic white goods retailers
Apr 16, 2009 | Washing Machines
Washing machine repair
What brushes???????? Most washing machine motors don't have brushes and I can't think of anywhere else there would be brushes.
Feb 10, 2008 | Washing Machines
Washing machine brushes
What brushes???????? There are none in the motor...
Dishwashers Logo
108 people viewed this question
Top Dishwashers Experts
