Partitioning Dear sirs, After completing a recovery, I find that there is now another partition on my hard drive. I moved all the information "my old disk structure" from the partition to "My documents" folder on C drive. I would prefer to have all my data on my c drive without any partitions. The partition size is 4.5GB. how can I delete this partition and increase the capacity of my C drive. I have never worked with partitions on any of my previous computers and I would prefer to continue in this manner. Thank you for your attention, I will await your reply.
  • Reltub Aug 29, 2008
    Thank you, the information was very helpful.The partition was labeled as "My old disk Structure" and I did manage to use many of my previously installed programs which were inserted by the recovery disk. This disk was created when I first started to use my laptop. I believe I can use it in the event of any future system failure, this maybe the reason I did not receive an XP disk when I first purchased my laptop.
  • Roberta Smith
    Roberta Smith May 11, 2010
    is the partion labeled with "system restore" or factory image ?
    Robert
    Genius:
  • 2,028 Answers
The partition was most likely set up by the recovery as a tool for future recoveries. The only way to get rid of the partition is to reformat the hard drive and install a new operating system. Partitions can only be created or deleted during the operating system set up process.
Posted on Aug 28, 2008
Missing partition
there are many freeware data recovery programs available on the web
http://download.cnet.com/easeus-partition-recovery/3000-2248_4-75279786.html
Easeus Partition Recovery is a free and easy to use partition recovery solution. It can solve the partition loss problems including partition deleted by accident, partitions lost due to virus attack, partitioning error or any other problems under Windows both 32 bit and 64 bit operating systems
hope it helps
May 26, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
Repair hard drive hey guys - i've had 2 500gb sata 2.5s fail, one was quite new and working fine externally, i formatted it and installed it on a customer's laptop (she left the charger out during...
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
also you could use a linux operating sytsem 100% free
or you could buy a disk you can get one for around $4.50 "cheap" or download one
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
Ubuntu is a linux operating system which can repair hard drives widows have corrupted and cant be repaired by windows operating systems
Hope this helps you
Oct 27, 2011 | Computers & Internet
Dear sir i have seagate ST3160215AS 160gb sata hard disk. in bios it shows 160 gb but in actual it gives only 149gb. i have tried to dm it but no dm matches it. then i tried ontrack to it. it shows 160 gb....
the hard drive might be damaged bad sectors
the operating sytem will take/use a certain ammount of space onyour hard drive
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
hope this helps you
Oct 23, 2011 | Computers & Internet
I have 1 gb thumbdrive and i want to make a small partition about 2mb in my thumbdrive for my machine...this machine can read 3 binary numbe only.........................
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Apr 28, 2011 | Computers & Internet
How do i use my second partition of my hard drive? my laptop is a dell vostro 1088. It seems that my OS (C:) is full but i see that i have a new volume(F:) so how do i use that? Originally, my laptop...
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
hope this helps
Apr 23, 2011 | SIB 320GB 5400RPM 8MB Cache SATA Hard Disk...
When i was partitioning my hard disk ,my battery has finished then when i have turn on my note book ,the machin wants the recovery disk but i had not this disk would you please help me ,thanks, ali
you will need the rescue disc that you should have created BEFORE you attempted to partition also partitioning a hard drive whilst on battery power alone was a very foolish thing to do. install the partition software you used on another pc and create a recovery disc with it. Then put that into the laptop and boot from it, hopefully it will attempt to recover the lost partitions, but dont be too hopeful of it actually doing it
Apr 06, 2011 | Sony VAIO EE Series Notebook VPCEE31FX/WI
It won't read the drive, it will ask to format, doesn't need to be formatted
use windows pe mini cd (google searche-burn on cd-boot) and choose hirens boot cd, select recovery tools.....inside there is alot of programes, **** the things is u need to know about basic partitioning schems to use partitioning tools and recover lost partitions, lost ids or lost boot record or stuff life that...if u never heard about those, then u have a better solution **** u need to have a secondary hardisk, to recover data frome the old on, all the programes u need are in the disk, if u pick the next solution u should choose the first option on boot, and its windows pe, there u should find recovery programes like active undelete and stuff like that..its really easy to use and effective...gd luck,, this is a visc stuff and infos on how to start thinking and were to start frome , if u have any questions i would like to help...
Dec 30, 2009 | Iomega HDD External Desktop (32660) 80 GB...
How can I merge two Hard Drive partitions together?
Nearly any partitioning software, even the built-in found on an XP install disk can repartition your drive. Partition magic is easier to work with. You can also find partitioning utilities at most hard drive manufacturer's websites. Or check out some of the shareware utilities here.
There is always a risk of losing ALL data on the drive when you repartition. It is likely the two recovery partitions are quite small. If the data on the drive is important it may be wise to leave it as is and simply buy an additional drive.
Jan 25, 2009 | Computers & Internet
FORTMATTING A NEW DRIVE
FORMATTING OR PARTITIONING A HARD DRIVE.
Formatting and partitioning a Hard drive will wipe out any and all information. Much like erasing recording tape.
Please be careful when attempting this procedure.
Partitioning a drive usually happens before the formatting process. Any drive can have up to 4 partitions.
Only one partition can be designated as active (the boot partition) one of the 4 partitions can be designated as an extended DOS partition.
When installing an Operation system ie: Windows (OS) The OS will bring you through this process.
However, on the other hand if you have an additional drive installed and you want your PC to see it, depending on what Operating system you have, you must navigate to the "Disk Manager" via the computer manager in the controlsettings of the OS. to see if the drive is recognized by the OS.
If it is, Right click on the drive and request a partitioning of that drive. Once the partition is complete, then request to format. this will configure the drive for the file format ie FAT or NTFS. In most cases NTFS is the format you would select. Additionally, you'll be requested as to the type of drive Logical or extended.
What you'll be doing with the system depends on how you Hard drive (HDD) will be partitioned out.
Remember the boot or active partition is where your OS will be and will be seen first after the PC boots (starts) up.
If you are using the system for home use, one partition is all you'll need. Lastly, you don't need 4 partitions on your PC unless you plan to use separate drives for say... backups, or to consolidate files. A lot of info I know... but if you go with one partition that maybe all you need.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future. If you need more help, feel free to keep asking, but keep the original information so I can see it.
Jun 06, 2008 | Computers & Internet
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
