Question about HP iPAQ HX4700 Pocket PC
Hx4700 not sync all items in calendar
My hx 4700 wont sync all that is on outlook program calendar with hanheld , all correct data is on desktop outlook calendar but some are missing on hanheld calendar. is there something i am missing?
    Master:
  • 450 Answers
So make sure that you are displaying all categories.... If while on Calendar screen, you click on Tools, Categories... then all category boxes shown , should NOT be checked. If any of them are checked, then you will only be seeing that category of appointments.
Posted on Sep 08, 2005
SOURCE:
Transfer my Address and Calendar data from Palm Vx to MS outlook
Hello. Take both devices to your phone store. They will transfer the data for you. J.
Jul 24, 2010 | Palm V
Suddenly, can't sync PDA
When duplicate items are resolved, are they normally dealt with automatically? If so then you could try to do this manually to get an idea of what the problem is.
Oct 02, 2007 | HP iPAQ HX4700 Pocket PC
How to sync palm data with Itouch? I have all my contacts & calendar on my Palm Zire. How can I get the same data over to my I touch in a Windows XP environment ?
You can sync to Outlook on the PC and then get the Outlook data onto the iTouch. If you have a newer PDA, It's install CD has a Sync options menu item where you can switch between Palm Desktop and Outlook. If you no longer have the original install CD or have an older device Pocket, Copy from Chapura.com It will move the Palm Desktop records to Outlook.
Mar 08, 2010 | Palm Zire 31 Handheld
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Caalendar on my desk top for my blackberry curve 8300
the blackberry will be using the Outlook calendar to update its information. its quite easy to use. What's happening is that the items calendared on the BB are syncing with the "private" calendar under the username (Outlook Today - Username - Calendar), and not the "public" calendar (All Public Folders - John Doe). No items are marked as "private" on the BB.
Install the Blackberry Desktop manager software and after its done go to the Syncronize Button. Once inside look to the left for configuration synchronization click this button it need you to be online to do this as well. inside it will list the many programs that can be used to sync your blackberry make sure you have already setup your outlook so that it can pick up the new settings your creating. once your all done look for the top upermost button on left of BDM ( blackberry desktop manager) and click syncronize to sync your blackberry. now once it is done your BB only needs to be plugged in and it will autosync itself. look in your outlook for new entrys and popup
Apr 14, 2009 | AT&T Blackberry Curve 8300 Smartphone
How do I synch outlook 2003 with iphone
You didn't say whether you're trying to sync everything (mail, calendars, contacts) or just some things or one thing (like contacts only). I don't know if you're using an Exchange server or even if you have the info you'll need to sync with an Exchange server.
I have a Windows mobile device (AT&T Tilt) running Outlook 2007 and everything is sync'd. We also started purchasing the iphone for our employees and sync their email, calendar and contacts to their phone.
I could probably give you step-by-step information (based on how I do this for my users at work) if I knew whether you'll use iTunes to do this or Exchange Active Sync and what you want to sync between your phone and outlook. One method (iTunes) will only update your data between Otulook and the phone when you connect it to the computer with Outlook configured on it but, the way we do it at work, they receive email, data, changes, etc in real time.
Try using this link http://www.apple.com/support/iphone/mail/
What you will find here is support topics and instructions for Exchange Active Sync, setting up email accounts, troubleshooting for contact and calendar syncing.
You can also search support on Apple's Web site. Entering the keywords: iphone outlook 2003 will bring up a lot of support info.
You can use iTunes or MobileMe for synchronization. If using iTunes then try this:
You can configure which items are synchronized during a one time set up process. After initial set up, each time you connect the iphone to your computer, the changes made on your computer or device are synchronized.
  1. Connect your iPhone to your computer. iTunes should open automatically.
  2. In iTunes, in the source list, under Devices, click the entry for your iPhone.
  3. Click the Info tab.
  4. Select which items you would like to sync. For example to sync only calendars, under Calendars, you would click Sync calendars from, and then click Outlook.
  5. Do one of the following:
  • To synch all calendars, click All Calendars.
  • To limit the calendars that are synched, click Selected calendars and then click the calendars you want to sync.
6. Click Apply.
Hope this helps!
Thanks for using Fixya and you can let me know how helpful I've been by rating this solution.
Apr 03, 2009 | Apple iPhone Smartphone
Handheld Calendar Does Not Sync
Is KsDatebook compatible with Palm? Palm suggests only two programs to sync calender files with Microsoft Outlook and the one that comes with the TX CD.
Jun 04, 2008 | Palm TX Handheld
Deleted appointments
Problem was solved by HP folks! talkinglens!
Sep 12, 2007 | HP iPAQ HX4700 Pocket PC
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
ActiveSync 'Unresolved Items'
At some point when I installed some windows updates, my Outlook started asking if I wanted to allow ActiveSync to access Outlook's data and for how long. Do you get a dialogue like this when you sync while Outlook is running? Could it be that when it's not running, you aren't given the dialogue and thus permission is not granted to ActiveSync to access the data?
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
119 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
