Question about Nintendo DS Console
US Nintendo DS-Lite with converter problems in South Africa
I'm an American living temporarily in South Africa. My son bought his American Nintendo DS-Lite, but we have been unable to charge it, though we have tried several electrical currency converters. Is there a particular converter configuration that we need to use, other than the standard 240volt to 110? Or can we purchase a new power cord in South Africa and use that? Thanks for any help. My son is frantic!
  • lalindsa Aug 28, 2008
    Could you be more specific please? What exactly is that charger, and how does it work with my US DS in South Africa? Can I use a differently powered charger on this DS? Thanks.
  • 2,071 Answers
Just click below;
Did you mean: ebay South africa to order nintendo DS lite Adapter
(function(){var s=document.styleSheets[0],l=s.rules,m=document.getElementById('mbEnd'),r,t;s.addRule('.s','width:auto');r=l[l.length-1].style;function c(){r.width=document.body.clientWidth-(m?m.offsetWidth:0)100){c();t=n;}});c()})()
Search Results
  1. Nintendo DS Lite AC Adapter Charger power Supply NEW! - eBay (item ... eBay: Find Nintendo DS Lite AC Adapter Charger power Supply NEW! in the ... In order to protect your order from loss or damage, shipping insurance must be
Posted on Aug 28, 2008
  • Nintendo Master
  • 6,487 Answers
If you can fidn a device like this there in Africa it will be better getting this so you can charge the DS while you're still there, check this link for it http://www.alibaba.com/product-gs/206489534/charge_station_with_blue_light_for.html
Hope that helps..........
  • Mark Gil
    Mark Gil Aug 28, 2008
    The charger that recommend to you will be better if only you can find a charger like that there in Africa, you just need to put the battery of the DS on that charger so you can go ahead and charge...
    Brigadier General:
  • 6,966 Answers
It should work straight out with a step down transformer. That is of course if the mains supply in South Africa is 240 240 and the unit being American is 110.
This is of course not unless it was initially tried without a transformer or stepdown converter which would mean that the charger/adapter has been fried and therefore damaged.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Aug 28, 2008
    Hi again,
    Possible replacement charger/adapter maybe found here, here or here.
    Alternately, I believe you could also charge the device using the USB port of your PC.
  • Louie  Role
    • Your initial post was "unable to charge it", if the original charger was designed for 110 and was inadvertently plugged into 240, then it would have been damaged and therefore would no longer charge the DS Lite. It would make no difference if you eventually tried using any "electrical currency converter". Hence my suggestion of purchasing a new one here, here or here.
    • Irregardless of the mains voltage 240 or 100, an appropriate charger will bring down the mains voltage and convert it to a usable power for what the DS Lite needs, specifically, 5VDC.
    • Yes, since it uses standard mini USB port meaning the voltage would always have to be +5VDC. For charging purposes, you could try chargers meant for MP3 players, cellphones, cameras, as long as they are USB ported. Having said this (USB), it is even possible to charge the unit using the USB port of your PC.
    The question really would be how long the charging time would be then with replacement USB ported chargers as different chargers/sources put out different charging currents but always 5 volts.
    Cheers.
DS doens't recoginize R4 card in my sons DS Lite. My other sons DS does recoginize the R4 card. Why? how can I get the card to work in both DS Lites.
Make sure you bought the correct R4 for the DS light and not the DSi. If you bought the correct one, then it sounds like the R4 cartridge is defective and needs to be exchanged for another one. Remember, Nintendo does not support the R4 cartridge, so go back to where you purchased it from.
Mar 23, 2011 | Nintendo DS Lite Console
DSlite purchased in UK, any usage problems in SOUTH AFRICA?
you wont have any problem with your dslite when you go to SOUTH AFRICA... you can use it as you like..
akuma_ryu21 rate it plss
Jan 21, 2011 | Nintendo DS Lite
My son has a DS lite. It was working fine and now
possibly fuses have blown on the logic board, but it sounds like it needs a new one board.
Jan 07, 2010 | Nintendo DS Lite
Where is NINTENDO DS Lite code located?
it should have been on the bottom of the DS, check maby your kids took it off, or contact NINTENDO
Oct 16, 2009 | Nintendo DS Lite Console
DS Lite - broken on/off button
Why don't you go to the nintendo website they can help you, you can explain your problem, ship of the DS and get it back fixed.
Mar 09, 2009 | Nintendo DS Lite Console
Nintendo DS Will Not Charge
Try if the battery is charged right, when batter is fully charged disconnect from AC adapter. Hold the power button for 5 seconds. If it does not work that means that you need a replacement battery for the Nintendo DS. When you receive the replacement batter, follow the steps again.
Sep 11, 2008 | Nintendo DS Lite Console
American PS3 in South Africa
Hey thomas952,
While they may not be region-coded, PS3 consoles and games sold within the United States are going to be NSTC compliant, instead of the PAL format used in the United Kingdom and South Africa. What this means is that in order for any game to display properly (or even operate) it must be purchased from the same region of the world as the console itself - NTSC games can only be played on NTSC consoles.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
French Nintendo DS Lite games vs American ones
it should do, i have a few Japanese games and Spanish games and they all work fine
May 27, 2008 | Nintendo DS Lite Console
USA to UK transformer
you need a step down voltage converter I bought one in USA for my american nintendo but they can easily be got here check out any large electrical outlet
Dec 25, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
230 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
