Webcam restarts pc????? arrggghhhhh
Hi
When I use msn messenger, I turn my webcam on, and it instantly reboots pc, what could it be? the system says the drivers are all ok and it is installed fine???
Martin
  • asgarali_aa Aug 30, 2008
    When ever i try to put the cam on it restarts the PC. Currently i am using windows XP. Advise please
    President:
  • 8,637 Answers
Normal 0 There are a number of things that can cause the camera to freeze up the computer or the camera.
First I’d check to see how much memory is installed in the computer. It takes additional memory to operate the camera.
Hope this helps. Bud
Posted on Feb 09, 2009
My logitech webcam won't work in msn messenger....in messenger when i try to make a video call...it says I need to buy or install a webcam? what's the deal? heeeelp
Hi Marilyn,
Have you installed the Logitech Quickcam program? If you did then open the application and select the instant messenger(i.e. MSN, SKype, Yahoo) that you will be using the camera.
If you have note yet installed the Logitech Quickcam application then I suggest you disconnect the webcam and run the software first.
Oct 28, 2010 | Logitech QuickCam Communicate STX Personal...
Not working with msn messenger
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Apr 06, 2010 | Logitech QuickCam Messenger Web Camera
Im using messesnger 10, my problems is i cant see my message and the message that i received. what can i do?
As you know this are mostly the problem with yahoo messenger... we are using different kind of operating system... All you have to do is reformat/reinstall your operating to run back normal again.
Why I give you this tip because even how many times your going to uninstall it, nothing will happen, changing directories on it at not possible to fix it.
Only reformat/reinstall the system is necessary.
Dec 26, 2009 | Yahoo Messenger
How to configure logitech with msn messenger?
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Click 'Finish'
Dec 09, 2009 | Logitech QuickCam Messenger Web Camera
I have installed the camera and it works fine in testing it.....but when i want to use to on MSN, it says there is no camera installed. i have unistalled and reinstalled but am lost how to get it to work?
HI,
First uninstall your msn messenger and then uninstall then webcam software/drivers.After that reinstall the webcam and then reinstall the msn messenger.
This should fix the issue.
Let me know the result.
Thank you for using fixya.
Nov 17, 2009 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
Apr 28, 2009 | Dell XPS M1530 Laptop
Webcam not workin on msn but workin on the notebook how do i get it to show up on msn messenger
Can you see an option of Live Update on the Acer? you will need to run that, download all updates, reboot & it should work ok for you then. Hope that helps. Merry xmas.
Dec 10, 2008 | Acer Aspire One PC Notebook
HP WEBCAM DOESN'T WORK WITH INSTANT MESSENGER
Are you using Flash Player on MSN? This sounds like you need to turn on access from the flash player setting menu. This sounds like another issue with the latest update of flash player. Also, you might try 'unchecking' the box for 'use hardware acceleration' in the flash player settings.
Apr 26, 2008 | HP Pavilion dv6000z Notebook
Toshiba Satellite A200-AH5 Troubleshoot
The type of pc is not as important as the type of webcam at this point. The story also needs more details.
If you had a Logtec webcam and at first it only worked with its custom made software, what did you do to make it work with MSN?
Based of the info provided, I would
1. uninstall all cam software while the cam is unpluged,
2. Reboot the pc. Then plug the cam in.
3. When windows detects the cam, it will ask for drivers, do not click on search on windows update website, click the option to choose from a specific location and then browse to the cd provided.
4. Try and load msn now. The msn website or the cam company sometimes have a patch to make the cam and the messenger work together. I would check the cam website before looking around the microsoft site.
Jan 11, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
