Question about Pentax Optio 555 Digital Camera
555 battery life problem/question
My battery life is often around 140-170 pics (with substantial but not excessive time reviewing, downloading, etc.) This sounds much lower than the "worst case" results that others have experienced. As an experiment, I just snapped off a bunch in a row and got 410 shots (1/2 with flash) immediately after a fresh charge. But, in day-to-day usage (with the camera sitting on the shelf for days or maybe a week in between outings) the battery seems performs much worse. Maybe my battery is somehow self-discharging over time at an unusually high rate? Or maybe the charger doesn't always do a consistent job... I really don't know. Have any of you ever experienced such weak battery life (~150 shots)? If so, I will just buy an extra battery and "live with it". But, if everyone here is getting much better battery life, I'll get my camera/charger/battery serviced. Please respond so I can decide what to do.
    Master:
  • 542 Answers
One way to find out If battery meets the specs. Take a fully charged battery and discharge it at 180Ma. As it is a 1800MaHr battery, it should deliver 180Ma for about 10Hrs.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
Let's see. I increase the RPM on my fan and it uses more power. I use a larger motor on the same size fan and it uses more power. Yes the startup time has decreased but that high power burst of startup is tough on batteries. Maybe it's a bad batch of batteries. I have seen that one user of the 555 has had good battery performance. I never saw any increase in the capability of my battery on my 450. 490 shots on first charge, plus 5 videos.
    Master:
  • 542 Answers
    Master:
  • 542 Answers
Do you think that motor speed would be such a big factor? I would have thought that unless the mass/resistance of the mechanism had changed significantly, the energy requirement to move the elements would be about the same, so power should not be the issue (more current; less time). Battery/motor efficiencies would have an effect, but it seems a bit much even for that compounding effect. I suspect something else must be going on. I have heard that for some batteries they do not achieve peak performance until several charge/discharge cycles. I hope that mine will improve over the next few months.
    Master:
  • 542 Answers
Before you conclude that my camera and battery are also misbehaving, I would point out that I have had the camera turned on a lot as I fiddled with focus, zoom, menu settings, more focus and zoom, etc, etc. There there is simply LCD viewing time to look at pictures I have taken, playing with in-camera editing features, more viewing, zooming in and out during review mode, etc, etc. Then there is downloading a few pictures at a time, which probably carries with it some USB overhead each time I connect and disconnect. So, in my opinion, I have not given the camera a fair trial of battery performance yet. Some day, I hope to go out and shoot at least a 256k memory card full of pictures before I have to recharge. Or maybe a few card's worth of photos to get that 400-600 shots per charge.
My fuji fine pix s9600 drianes the life out of the battery with in minits is there a fix
This is from the What Digital Camera review (quoted for the purpose of review only)
'When it comes to playback things are a little less satisfactory, with a noticeable delay scrolling between images and the battery life using regular AA cells is disappointing - a set of copper-top Duracells expired at around the 200 frame mark, which may be OK for a day's shoot, but NiMH rechargeables or Energiser Lithium cells are preferable.
Read more at http://www.whatdigitalcamera.com/reviews/compact-cameras/fujifilm-finepix-s9600#l6gtyijBLdtVH9HI.99
So, looks as if you need high power batteries, or else re-chargeable cells. Normal cheapo-cheapo ones will drain rapidly.
Nov 18, 2016 | Fuji Cameras
Advent 9315
Sounds like you may have a shorted battery. Time to purchase a new battery.
Mar 16, 2014 | Computers & Internet
Two things....my approx.18 month old battery died and i bought a replacement yesterday. is this the normal life expectancy? 2nd. Today, with a totally charged battery, I took eight pictures. Later I...
To answer your questions, depending on how much use, (meaning how many snap shoots) will dictate whether your camera has reached its life expectancy. The proper procedure for long life with the battery is to have it totally drain out before charging it. If charged too soon the battery has a memory and will only work as long as the short period the battery was charged. It sounds like camera is worn out. Good Luck
Jan 07, 2011 | Kodak EasyShare M1033 Digital Camera
Recently purchased the Sony DSC-W290 and I have
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
Apr 08, 2010 | Sony Cyber-shot W290 Digital Camera
Toshiba Satellite A105 - S4547, screen goes black when using the battery (not plugged in)
check your control panel/video to ensure device driver is current. use driverguide.net.since when on battery no pic suggests that the battery life span is shortened. Recharge and check how long the battery level lasts when doing normal internet or document reviews. Video playing drains the battery at a high rate, when battery is already low, virtual memory tries to assist.
Jun 28, 2008 | Toshiba Satellite A105 Notebook
Kicker cvr and ameican legacy 2000 watt monoblock amp. I just need to know if this would hit hard? n if der is anything i need so i wunt damage my 2006 malibu at the same time
The amp, i am not so familiar with, so do your homework...
You want to pay attention to sound quality specs such as signal to noise ratio (the higher the better, like around 100 ) and THD (total harmonic distortion, the lower the better, like between .1% and .001%) If your amp is putting out 2000 watts at a high distortion level such as 1%, you wont be too happy with the quality and you may blow your sub before ever approaching the full 2000 watts.
As fara as your car goes, a heavy duty capacitor would well placed between the battery and the amp, and upgrading the alternator may be considered. If not, you are looking at substantially shortening the life of both your battery and present alternator.
Feb 26, 2008 | Car Audio & Video
LIfe of batteries
make sure with any lithium ion battery operated device, that you drain the battery completely when you first get it and then charge it the maximum number of hours it states in the manual. To avoid over charging, don't charge it again until that full charge is once again depleted. This will give you maximum battery power
Jan 12, 2008 | Samsung Digimax S730 Digital Camera
Vivitar
i have done exactly the same as you mate, 2gb SD maxell card, dosent function, however when we where at a family get togther i swaped cards with a mate, so i gave him my 2gb card to put into his camera which wan not a vivitar and gave me his 64mb sd card (cant remeber the make of his) and my vivitar 3720 worked fine, with his card... and my card worked fiine in his camera...
so i think its just that the vivitar cant take upto 2gb... try buying or even swaping your card for a lower memory..
i will be doing this, just havent got round to it.
Hope this helps.
take care.
carwyn
Dec 27, 2007 | Vivitar ViviCam 3720 Digital Camera
Disk error c:13:00
A substantial percentage of my Memorex 3.5" CDs won't finalize, and when I susbsequently try to review the photos on the camera, it tells me there are no files on it. Nothing will download to the computer via the USB either. A substantial percentage of my Memorex 3.5 "CDs won't finalize, and when I susbsequently try to review the photos on the camera, it tells me there are no files on it. Nothing will download to the computer via the USB either.
There is a software program that always saves me when I get careless and fill the disk to full. It''s called CD Roller. It''s called CD Roller.
Nov 09, 2007 | Sony Mavica MVC-CD400 Digital Camera
S2 suddenly draining batteries rapidly
I have the same exact problem. I just now read a possible solution: try opening the battery compartment door and then closing it again to "trick" the camera into thinking it just got new batteries. There is definitely something wrong with the way the camera senses dead batteries.
Jul 28, 2007 | Canon PowerShot S2 IS Digital Camera
Pentax Optio 555 Digital Camera Logo
46 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
