Question about HP iPAQ RX3715 Pocket PC
Memory I've got a rx3715. Why is it that whenever you close a program by clicking the "OK" or "X" buttons the program continues to run in the background? Last night I tried to open a program and it said I didn't have enough memory. So I looked into how much memory was available and it was basically nothing. But when I looked under running programs, there were about 6 or 7 programs in there. They were all the programs I had previously used. Shouldn't the programs stop running when they are closed?
    Master:
  • 450 Answers
Your options: from time to time go to Running Programs and close what you're done with; or, as you're leaving a progran, check whether it has an Exit or Quit command; or, open iTask, tap and hold on the name of a program, and choose Close this Task from the pop-up menu; or, my favorite, use the on-screen keyboard and tap Control and then Q (upper or lowercase)--that'll work with almost any progran that accepts text input.
Posted on Sep 08, 2005
SOURCE:
Data execution prevention as I am getting this messaGE WHENEVER i GO TO OTHER WEBLINK AND iNTERNET eXPLORER SHUTS OF SO i NEED YOUR HELP
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply. 1. Start\Control Panel\System and Maintenance\Performance Information and Tools\Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.Disable DEP using CMD A) In the command prompt, type bcdedit.exe set {current} nx AlwaysOff and press Enter.B You should get a success message back C Close the command prompt. D Restart the computer to apply. Enable DEP using CMD A In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter. B You should get a success message back C Close the command prompt. D Restart the computer to apply.
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.Follow the steps below to to close Data execution prevention a. Click on start. b.Right click on Computer and click Properties.c. Click on Advanced system settings.in upper left green area d.Click on the Continue button in the UAC prompt.e Click on the Settings button under Performance section.f Click on the Data Execution Prevention tab. g. Turn DEP On for Essential Windows Vista Programs and Services Only.NOTE: This turns on DEP for only the 32 bit system programs and services. This is the default setting. h.Click on Turn on DEP for essential Windows programs and services only.click on OK to apply. j.Turn DEP On for All Programs and Services Except for the Ones you Select.NOTE: This turns on DEP for every 32 bit program except for the ones that you add to the list. The listed program will have DEP turned off for it.Turn on DEP for all programs and services except those I select. Click Add to add the programs that you do not want to use the DEP feature. m. Navigate to the program's .exe file that you want to add to the DEP exclusion list and select it, then click on Open. n.Click on OK to apply. b. Restart the computer to apply changes.
Oct 24, 2011 | HP Pavilion DV6000T 15.4­ NOTEBOOK LAPTOP...
Message states msn toolbar has error code 400. how do i fix this
I would suggest you to uninstall the toolbar and check. Follow the steps mentioned below.
a.Close all Internet browsers.
b.Uninstall the toolbar through your "Add/Remove Programs" utility. Choose the "Start" button in the lower left-hand corner of your computer screen, and then click "Control Panel." Choose "Add/Remove Programs" and the programs that are installed on your PC will be listed. Choose "MSN toolbar" and then "Change/Remove." You will be instructed to verify if you wish to continue with the uninstall. Choose "OK" and continue to follow the instructions by choosing "Next" until the uninstall completes.
c.Uninstall the toolbar by using the "Run" utility if you are running Windows XP. Click "Start" and then "Run" and type "appwiz.cpl" in the text box. Press "Enter" and the programs that are installed on your PC will be listed. Choose "MSN toolbar" and click "Remove." You will be instructed to verify if you wish to continue with uninstall. Choose "OK" and continue to follow the instructions until uninstall completes.
d.Open a browser and verify that the MSN toolbar is no longer displayed. You may need to restart your PC after uninstall is complete.
May 17, 2011 | Microsoft Internet Explorer 7
My hp pavillion dv6000 wont start normally. in safe mode will start but continues to request product key when i log in with my password.
It seems to be an issue with some software that is conflicting with the operating system. I would advise you to clear the start first. The steps below would help you clear the start up.
For XP:
  • Click on the start button(with the windows logo on it) on the bottom left corner of the screen.
  • Click on Run.
  • A small pop up box would open at the bottom left corner above the start button.
  • In the dialogue box beside "Open : " type "msconfig" and hit enter.
  • System Configuration Utility would open.
  • On the top menu, identify and click on Start up.
  • Now, click on the button "Disable All", at the bottom right corner. This will disable all the start up programs. However, you will still be able to access all those programs from Start->All Programs.
  • Click on "Apply" and then click on Ok/Close. If "Apply" is grayed out, click on Ok/Close. If administrator password is prompted, click OK and proceed with the steps below.
  • You would see another pop box with 2 options, "Restart" and "Exit Restart" or "Restart Later". Do not worry, if you do not get this option.
  • Restart your computer.
  • Immediately after your computer restarts, you will see a pop box. In that box, CLICK TO CHECK THE RADIO BUTTON AND ONLY THEN CLICK ON OK.
  • If you forget this step, you will have to start over again.
  • Your computer should have now booted to normal mode.
For VISTA or Win 7:
  • Click on the Start button (with the windows logo on it).
  • Click on Start Search and type msconfig.
  • On the top, under programs, you will find a link for msconfig. Right click on msconfig and click on Run as administrator. Click on continue (in user account control box).
If you still face the same problem, you can download and install the BIOS update.
If any of the above steps do not work, then it could be an issue with windows updates and any other updates that might have created a conflict. In this case, restore the computer to an earlier date when it was working fine. For that, follow the steps below.
For XP:
  • Click Start.
  • Click Help and Support.
  • Type system restore in the Search box, and then press ENTER.
For Vista or Win 7:
  • Click Start vistastartbutton.jpg, type system restore in the Start Search box, and then click System Restore in the Programs list.
  • If you are prompted for an administrator password or confirmation, type your password or click Continue.
  • In the System Restore dialog box, click Choose a different restore point, and then click Next.
  • In the list of restore points, click a restore point that was created before you began to experience the issue, and then click Next.
  • Click Finish.
Hope all this helps you.
Still if this does not work, then contact an expert who can help you with doing more troubleshooting on this in recovery environment. In recovery environment, we can try sfc /scannow and check /r.
Good luck.
Dec 18, 2010 | HP Pavilion dv6000z Notebook
Error loading winyvf32.rom
http://www.superantispyware.com
Please run ATF and SAS:
Note.. SAS doesn't open the registry hives for other user accounts on the system, so scans should be done from each user account.
Note 2: On Vista, "Windows Temp" is disabled. To empty "Windows Temp" ATF-Cleaner must be "Run as an Administrator".
From your regular user account.. Download Attribune's ATF Cleaner and then SUPERAntiSpyware, Free Home Edition
Save both to desktop .. DO NOT run yet. Open SUPER from icon and install and Update it Under Scanner Options make sure the following are checked (leave all others unchecked): Close browsers before scanning. Scan for tracking cookies. Terminate memory threats before quarantining. Click the "Close" button to leave the control center screen and exit the program. DO NOT run yet.
Double-click ATF-Cleaner.exe to run the program. Under Main "Select Files to Delete" choose: Select All. Click the Empty Selected button.
If you use Firefox or Opera browser click that browser at the top and choose: Select All Click the Empty Selected button. If you would like to keep your saved passwords, please click No at the prompt. Click Exit on the Main menu to close the program.
NOW Scan with SUPER Open from the desktop icon or the program Files list On the left, make sure you check C:\Fixed Drive. Perform a Complete scan. After scan,Verify they are all checked. Click OK on the summary screen to quarantine all found items. If asked if you want to reboot, click "Yes" and reboot normally.
To retrieve the removal information after reboot, launch SUPERAntispyware again. Click Preferences, then click the Statistics/Logs tab. Under Scanner Logs, double-click SUPERAntiSpyware Scan Log. If there are several logs, click the current dated log and press View log. A text file will open in your default text editor. Please copy and paste the Scan Log results in your next reply. Click Close to exit the program
IF THIS WORKS then create restore THEN do following steps
• Go to Start > Run and type: Cleanmgr
• Click "Ok"
• Disk Cleanup will scan your files for several minutes, then open.
• Click the "More Options" Tab.
• Click the "Clean up" button under System Restore.
• Click Ok. You will be prompted with "Are you sure you want to delete all but the most recent restore point?"
• Click Yes, then click Ok.
• Click Yes again when prompted with "Are you sure you want to perform these actions?"
• Disk Cleanup will remove the files and close automatically
Dec 11, 2010 | Microsoft Windows Vista Home Premium...
I get a memory error whenever a Pogo games starts loading; then internet explorer closes. However, 2/3 of memory is free.
2/3 of your hard drive is free not memory. The memory can be freed up by going to start menu, run and type in msconfig
In this window, go to the startup tab and uncheck all programs that start with the computer. Click apply and then reboot.
Memory shortage is caused by alot of programs running in the background of your computer. Every single program you install, by default, runs in the background when your computer starts up. The method above will kill all programs from starting up and save you memory.
Sep 11, 2009 | HP Computers & Internet
ERROR MESSAGES ON COMPUTER
I just want to check with you - is that the full error message? Usually it's something like: "The instruction at '<address>' referenced memory at '<address>'. The memory could not be read." So, there might be an address missing. Also, what operating system are you using?
You might try running memtest86 to see if there's anything wrong with the physical memory in your system: http://download.cnet.com/Memtest86/3000-2086_4-10524193.html
You could also try this if you have IE7:
1. Open Internet Explorer.
2. On the menu bar, choose Tools > Internet Options.
3. Click the Security tab.
4. Select the Internet zone and click the Custom Level button. The Security Settings window opens.
5. Scroll down to the Scripting section of Settings.
6. Under Allow paste operations via script, select Enable or Prompt.
7. Click OK to close the Security Settings window.
8. Click Yes when asked if you want to change security settings for this zone.
9. Click OK again to close the Internet Options window.
Jun 11, 2009 | Dell Computers & Internet
Window closing Problem
I think you have a bad memory chip or bad motherboard RAM bank.
You should do a RAM memory check. If you look in the EventViewer by going to Start | Run | and typing "eventvwr.msc". You may see events there that will indicate what and why.
Or, you can search for a Memory checker on the internet and use it to reboot and test your memory on bootup.
Nov 28, 2007 | IBM xSeries 346 Server
Rx3115 won't show close button
Jul 14, 2005 18:26:04 GMT unassigned Well, this isn't a solution, but rather a way to work with it until you find the solution. On my rx3715, I have something called iTask. I have a button I can press on the unit that brings it up, or I can go to Programs and tap on iTask. Once it's up, I can see which programs are running and close one or all of them. Another way, if you don't have iTask or something like it, is to use your memory settings to close programs. On mine, I go to Settings>Memory and then the Running Programs tab. From there I can "stop" any program. I know this doesn't solve the problem, but now at least you'll be able to close all those programs. For a solution, I'd try doing a soft reset. If that doesn't work, do a hard reset. Maybe someone else will have some better ideas.
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
Increasing Memory
The bad news is that many of the programs you might like to do away with are built into the ROM, and can't be deleted. The good news is that most programs will run perfectly well if installed on the storage card, so if you've got programs installed in main memory, you can realize some savings by running them from the storage card instead.. If you go that route, be sure to Remove the program from main memory and then re-install it to the storage card.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
Calendar question RX3715 / Windows 2003SE
yes the default is that the ipaq only keeps the past two weeks. To change this, open Activesync on PC, double click on Calendar.
HP iPAQ RX3715 Pocket PC Logo
55 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
