Question about Energizer Rechargable Battery with Charger
Battery Charging Problem
Going on a vacation in Europe, understood that the power there is 220V, i have the adapters for the plug, but i was wondering if i can charge US batteries which are built for 110V with a 220V?
  • 30 Answers
The problem is not with the batteris, but with your charger, you have to make sure it can take 220V or you will burn it. Look for a switch on it to change from 110V to 220V.
Posted on Aug 28, 2008
Whirlpool electric dryer 220V bought in USA and brought it to Europe Serbia. I was told that USA 220V and Europe 220V is not same. I did not plug it in yet can someone tell me what to do. Thanks
the voltage is approximately the same,the difference is the frequency of incoming power as power delivered in the USA is at 60 Hz. and power in Europe is at 50Hz. so some electronic parts will not operate on this frequency,you might be able to purchase a power/frequency inverter unit but not sure on this,talk to your power provider as they may have the answer to this
Dec 04, 2012 | Whirlpool LER4634J Electric Dryer
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
I have a Netgear wireless router WGR614 v5 with the AC adapter of 120V-60Hz-16W. I've moved to Europe where the electricity is 220V. Can I use an AC adapter of 220V for this wireless router? Thanks a lot...
Yes, make sure you have a new power supply with the right voltage output, enough current (if the new power supply is rated for more current output, it will be OK), and the right plug with the right polarity.
Check your power supply, some will actually work with a wide range of voltage, some actually go from 100-250VAC. 50Hz-60Hz
Jan 05, 2011 | NetGear WGR614 Wireless Router
What will happen if I plug my 110V tv into a 220V receptacle?
If you want to fry your electronics or appliances that's it's a sure way to accomplish that.
While appliance working ONLY at 220v will just not work or under perform (like a hair drier) when plugging electronic equipment that runds ONLY at 110v then that item will be "fried" as all its electric components will be burnt as it will receive twice the power that it was build to receive. Should that happen the safety switch on the 220v circuit where the item was MISTAKENLY plugged will be triggered (hopefully or there will be risk of fire and serious injuries, even death) and the power will be shut off. That's a major but possible mistake.
If traveling abroad those who come to US will unlikely damage their appliances (like electric razors) as they will receive less power (110v vs 220v) and usually these items are protected against these mistakes by the specifications of their own design. The opposite is not true of course as just mentioned above.
So do not play around with dangerous items please! ;) On a positive note though: Nowadays most appliances have dual power and should work whether plugged in a 110v, 60Hz (most common in US) or 220v 50Hz (most common in Europe). So nothing really happens... it just works as long as you have the proper adapters to plug the appliance to the different receptacles.
Note: One of the differences is that (without going into the math of it all), an appliance working at 110v will draw x2 times the power than it draws when working on 220v so if an appliance was drawing 3A at 110v it will only draw 1.5A when working at 220v.
Best.
Jul 05, 2010 | Televison & Video
Toshiba Laptop not charging
So confusing...Laptop AC Adapter nowadays has AUTOMATIC VOLTAGE, meaning it doesn't matter if it is 110v or 220v. Maybe you've got a FAULTY BATTERY. Remove the battery and plug in your AC Adapter to outlet and to your laptop and try to power-on.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
Canon powershot sd750
The AC adapter for the battery charger shoud work from 110V-240V with auto detection for voltage. Look at the marking on the AC adapter and the input voltage should show 110V-240V. Once you verify this, the charger will work on 220V and you will only need the outlet adapter.
Jan 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Ps3 power
Try and find a better/different adapter, maybe one the is specific for the PS3 or gaming in general. Don't use one of those universal ones, could fry your PS3.
Not sure what kind of outlet/plugs you guys have out there (I'm in Canada, eh) but I've provided a couple of links that should help you out. Personally, NYKO is a great choice, quality stuff and they have lots of accessories for the PS3.
http://discoazul.co.uk/powercord-nyko-ps3-european-plug-adapter/product_info.php/products_id/3206
Due to the volt difference; Europe (220v) vs. Canada & US (110v)
you MIGHT also need a power converter. Check the console, it will probably be able to handle 110v-220v but double check to be sure. I have heard all kinds of answers and opinions about it but best to check your PS3 yourself. If it odesn't support both voltages then you will also need to get a power converter.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Energizer Rechargable Battery with Charger Logo
216 people viewed this question
Top Energizer Electronics - Others Experts
cwradio73
Are you an Energizer Electronics - Other Expert? Answer questions, earn points and help others
