This problem should be removed because:
Problem with PC Laptops
Compressed boot manager
Can't open the laptop!
Message: compressed boot manager; press ctrl+Alt+Del to restart the computer.and fails to open Window Vista Ultimate.
Any useful tips to solve this problem?
Trunky
Solutions (3)
Best Solution
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
If the boot partition no longer can be found, then Vista will display the following error:
BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If by accident having compressed the entire boot partition, then Vista will display the following error:
BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
- compact /U C:\bootmgr
- compact /U C:\ntldr
Insert installation dvd
Click repair my computer
Try letting it fix it by using the startup repair
If that fails then cancel till you reach the menu where you can select the c: prompt.
Now write cd\Windows\system32
Then you have to use the bootsect
command.
Write bootsect /nt60 c:
Now restart the computer.
Thanks it's work
1) Insert installation dvd
2 ) Click repair my computer
3) Try letting it fix it by using the startup repair
4) Now write :-- cd\Windows\system32
4.1 ) Then you have to use the bootsect
5) Write:---- bootsect /nt60 c:
6) Now restart the computer.
screen freeze
everytime i start up my Acer aspire 3690 i get a screen freeze and all of a sudden all the windows disappear and i'm left with the...
boot mgr is missing
bootmgr is missing
upgraded to window vista
and now its on reduced mode functionality! how can i remove this program from my notebook? when i turn it on, it gives me boot compressed...
boot manager is compressed. Press
boot manager is compressed. Press ctrl+alt+del to restart. Same happens when i restart. My cd/dvd cant read cds or dvds
Add Your Solution
toshiba p3500 bios password reset
Hi, I have Toshiba p3500 pc, it has power up password, how can I reset this password? Thanks for your helps.
How to connect IBM Think Pad t60 laptop to my...
How to connect IBM Think Pad t60 laptop to my Nokia 2710c or Nokia E63 to use it as moderm so I can use internet. Please...
audio not working
Driver already installed still not able to hear an
Fix-O-Meter
9,025
9,025 people viewed this problem
- 8 people found this problem to be helpful.
- 1 person is following this problem
Top PC Laptop Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
