Laptop does not seem to charge when I plug the charging lead in. Occasionally it will work if you twist/turn the head of the lead. Need to know if its a lead or laptop problem
    Brigadier General:
  • 6,966 Answers
If it works part of the time, then chances are that it is a minor problem. Your options then are:
  • AC adapter plug. To check, use a DVM while the adapter is plug into the mains. Measure the output voltage while bending/twisting the junction of the wire to the plug. Voltage reading should not cut out and remain steady. If not, the plug has to be replaced and the wire cut about an inch from the junction;
  • If the adapter's plug checks OK, then it would be the jack of the laptop. Often problem would be a loose connection or a cold solder. This is a relatively easy repair, however, what is more demanding is opening the casing of the laptop and exposing the bottom side of the board in order to re-solder the jack pins to the board.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 28, 2008
What means when the power light keep turning on and off
Hi Essa
Have a look in your manufacturer's handbook/manual.
It's more than likely the lights flash but not charging your laptop because it has sensed that there is a charging lead plugged in but the laptop is not receiving current. This could mean one of two things:
1. The charging socket is faulty and needs to be replaced
2. The Charging lead is faulty (wrong laptop lead or non genuine)
If you have a multimeter and you are proficient in it's use you can check the voltage coming out of the charging lead to see if it's working or not.
Regards
Andrew
May 18, 2014 | Computers & Internet
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
The fans run but the computer fails to turn on
Likely either a bad power connector (common) or the charging circuit on the motherboard may have a problem.
Oct 12, 2009 | Toshiba Satellite P35-S611 Notebook
E machine 510 wont charge!
Yes, remove the battery from the laptop.
Plug-in power adapter and turn ON laptop (without battery).
After the laptop starts up and Windows has settled, put battery back in the laptop.
Allow to charge for a few hours.
Oct 07, 2009 | E-Machines eMachines Desktop PC
Charging, but no power compaq precario
Hello, Did you twist any of the wires/cable on your charger? Can be a problem on the plug, try, very gently, to turn it, if round that is, and see if theres is a contact in between. Regards.
Jun 11, 2009 | Compaq Presario Notebook
My Laptop will NOT charge! What do I do?
It is obviously not charging. Either the battery is defective, the power adapter is not getting power, the adapter itself is defective, you're not using correct adapter or power outlet is no good.
Try to see if theres any light at the laptops jack where you connect the power, if not theres no power getting in.
Try to remove and insert the battery again.
Make sure all power connections are secured
Try removing the battery and just plug it the power adaptor to isolate the problem.
Try another power outlet
If plug in to power strip, try resetting strip by turning off and on
If none of these work then you may have a defective jack in your laptop.
Jan 12, 2009 | Compaq Evo N610C Notebook
I don't know how to charge my battery
Its ok. Um just leave the battery plugged into your laptop and the power cord plugged into the laptop as well and the laptop will charge it for you. If it won't, the battery is no good and get a new one but you don't need a external battery charger to charge your laptop battery.
Nov 21, 2008 | Dell Latitude D600 Notebook
Compaq laptop
Try removing the battery and starting on AC only.
Jul 19, 2008 | Compaq Presario Notebook
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
