Question about HP Office Equipment & Supplies
Printer won't print
I have a HP 4315 printer. It says it's offline, how do I get it to print? I've checked all connections and everything is fine. Please help.
  • 50 Answers
Reinstalling you printer would help solve your problem :)
Posted on Aug 28, 2008
4315 no connection
Hi
Using USB connections?If you were installing the printer,note that you should not connect the usb untill the on-screen instructions prompt you to connect it.
If you had already installed printer,then check the usb connections.
Disconnect it from power and PC and then reboot the PC.
Connect everything again and then try printing.
Feb 23, 2012 | HP Officejet 4315 All-in-One Printer
My HP officejet 4315 v All-in One is set as my default but the status shows offline, how do I turn the status to ready and to be able to print from the computer?
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Feb 06, 2011 | HP Officejet 4315 All-in-One Printer
I cannot print to my printer...it says it is offline...how can i fix that? its connected to the network and all network cables are working fine...
may be you should check, in first, in the control panel / printer ; right click on the icon of your printer , verifier that it isn't setup in offline mode , otherwise i don't know ....
Jan 14, 2010 | HP LaserJet 1320 Printer
HP Deskjet 3500 series, my printer keeps telling me that is is off when the light is green, keeps stating it is offline. When I installed the printer everything was fine, now when i print the printer...
Hi
HP Deskjet 3500 serie --
There could be a Software issue or hardware issue --
1) To check the software issue
Print a Test Page -- from the computer
2) To check the hardware
Press the Power button to turn the product on.
Press and hold the Power button
Open and close the front cover four times.
Release the Power button. The self-test will print
and it it is printing the hardware is fine ...
3) Then you can check by changing the USB Cable connection
Jan 01, 2010 | HP DeskJet 3520 InkJet Printer
Won't print and says it is offline
it is due to the chords are not connected correctly.Reconnect the chords.
Sep 11, 2009 | HP Officejet 4315 All-in-One Printer
On Control Panel it says the printer is offline...forget how to make it online! HP 4315 All in One
Hi there
Are you absolutely sure the printer is connected securely from both ends of the cable and turned on? If so, try turning it off and on again. Did it come online?
If not, how is the printer connected to your computer? Is it by USB cable, or via a network cable? And also let me know your operating system like XP or Vista etc.
Thanks.
Jul 13, 2009 | HP Officejet 4315 All-in-One Printer
HP Officejet 4315 All-in-One went offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Officejet 4315 All-in-One Printer
Problem with hp officejet4315v all in one
Hi there check that the data cable hasn't fallen out if not change data cable. If still not working check that you are using the correct port within the driver .
  • Goto Printers and faxes
  • Make sure that the printer states Ready not offline
  • If states offline Right Hand click and select use printer Online
  • If not above right click and select properties
  • Once in properties select Ports from the Tab at the top of the window
  • Make sure that you are using the correct Port i.e. LPT1 or USB that the printer is connected to.
  • If you aren't change the port by clicking the appropriate one or add new port.
  • If you are on the right port try reinstalling the print drivers
I hope this helps you
Thanks J
Jan 13, 2008 | HP OfficeJet 4315 All-In-One InkJet...
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
