Water will not drain away and will not spin. - Washing Machines
    President:
  • 1,462 Answers
You haven't said make or model but check filter and check for foreign object jamming the pump impellor
Posted on Aug 28, 2008
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
Why has my machine not drained or Spun.
Cant be 100% but could be overloaded, turn off, set dial / program to spin and try again, may need several goes to empty.
Jan 13, 2016 | Washing Machines
Duet sport washer dosnt spin drain pump is working
If all the water is not draining away then check the filter for blockage. A machinme will not spin if it has water in it.
Oct 01, 2014 | Whirlpool WFW8300SW
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water continues to drain on the spin cycle while filling
there is no actual drain valve, but rather physics to keep water in tub.
The drain system MUST be located HIGHER than the deck fo the machine, with console height being preferred.
Drain during spin cycle is normal, as rinse is intended to also drain away at that time..
Doc
Sep 18, 2009 | Washing Machines
ALL FUNCTIONS OF WASH CYCLE WORK EXCEPT WATER WONT DRAIN AND SPIN CYCLE WONT WORK,
Pump is blocked or shot
Pressure switch made telling the machine it is full of water hence no spin.
Drop hose into bucket to drain the water off and the machine should spin, you may be better dragging the washer to an outside door and let all of the water run away at once .
Make sure that the drain hose is unclipped from the back of the machine so that the bottom of the hose is as low as you can get it
Jun 25, 2009 | Roper RAS8445KQ Top Load Washer
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing machine won't drain
Check the drain hose, look for obstructions,
If dran hoe is fine, and it does not drain it is probably a faulty or obstructed drain pump.
See the following indications from repairclinic : It won't drain
Sep 09, 2008 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
