Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi Wd-52525 HDTV Stutis light constant red
I am wondering what might be wrong with our 52' Mitsubishi WD-52525 flat screen HDTV. When you go to turn on the tv the timer light blinks green for about a minute and then the tv trys to turn on, I heard the sound, then it fails and the status light turn a constant red. We have had the tv a little over 14 months and have not replaced the lamp. However, the lamp light is not red and we have never received a warning message on the tv about the lamp being about to fail. How would one know if the lamp needs to be replaced? Additionally, we cleaned the filter, and tried a system reset over the phone with Mitsubishi to no avail. We would like to fix this ourselves rather than have to call someone to repair it. Any idea what the problem might be? All advice is welcome and greatly appreciated. came home to find the timer light blinking and i cannot turn the TV on or the timer light off
  • jesseaj2002 Sep 09, 2008
    I also have a wd-52525 and I replaced the 4 capacitors
    (C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) , and also 2 other capacitors (3300uf 10volts) and my tv went from not starting up to starting up with a bunch of columns and lines going through them covering the whole screen...what is my issue now? please help
  • 927 Answers
Good Day, barryspiegle.
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 50 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Posted on Aug 30, 2008
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced bulb in Mitsubishi WD-52525 and it still does not work
What does not work? Does the green light flash or light at all? Can you "manually" turn on the tv? If the light is RED...the replacement was either installed incorrectly (or is not plugged in correctly to the contacts at the rear) or is the wrong bulb. Be sure the door to the front of the bulb in on as there is a micro-switch at the lower right that MUST be engaged.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
May 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No signal, blue screen
If no video and OSD is good then: Suspect the Signal PCB part # 930B923002
Sep 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Here is the link to the manual if you need it; page 97 states that the lamp is the problem -(the flashing green just means startup - page 11) 14 months sounds about right for a new lamp if you use it a lot - that would be an average of 5&1/2 hours a day if the lamp went to 4000 hrs - although these lamps are more dependable than normal lamps, they can still fail anytime especially if they have been touched on the glass by accident while installing or cleaning, or if the tv is often switched on and off. The fact that there was no message on screen may mean that the lamp has not gone past the warning trigger number of hours - sorry i haven't found what that value is. page 95&96 gives all instructions how to replace lamps and where to get spares - if the price seems bad then search around - prices often vary a lot on these lamps. It is a little disappointing that mitsubishi where not able to diagnose this - please let them know that their technical service is poor in the hope that they try harder. I hope this helps :) Hope this helps :)
Mar 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
217 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
