Question about Toshiba e830 Pocket PC
Rom Update Since I got some problems with my PDA, may be someone here can answer me: 1) The center switch of the "previous window function" is not work (of course I have enabled this function and release the "HOLD" lock.) 2) The slide show screen saver always running after the desired wait time when docked, no matter I have tipped the screen/worked with the PDA or playing movies in the wait time. 3) Some problems with 1G SD card, which will make the PDA unstable. Sometime the data in the 1G SD Card will lost or scratched. 4) Sometime, the Bluetooth does not work, and required a reset. 5) No stereo bluetooth stack profile.
    Master:
  • 903 Answers
As far as I know there is a big difference between Japanese and European images and you can not compare them at all. If the Japanese image has a bug or if there is some problem that can be corrected with a new update that doesn’t mean that European units needs an update too. Many of your questions are not completely understandable and I can just give you an advice to use a new BT driver (question 5). I have also 1 GB SD card and I use it with my e800 without any problems. At the beginning I thought that it will be read slowly but I am very satisfied with reading/writing speed.
Posted on Sep 08, 2005
SOURCE:
Tried to update iPAQ ROM, iPAQ died in middle of Install. Help!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.) Make sure battery is charged
2.) Locate the rom you want to use
3.) Remove machine fro cradle
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your PDA in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Highlight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from your Vendor in step 3.
10.) The PDA should now begin Flashing the iPAQ's ROM BIOS.
Aug 21, 2009 | HP Computers & Internet
Hi there, I Like to upgrade in my I-Mate JAQ OS WM 5 TO OS WM 6,1 or 6,5 if its is possible.Please show me how to do this. Thank you, Aleksandar
Hi, I'm afraid there is no offical or unoffical ROM upgrade for your PDA yet (ROM is the place where the PocketPC operating system is stored, and each device model has a different ROM so sadly you cannot use any other Windows Mobile 6 ROMs with your device.). I am giving more details about this issue to make it clear. Still you can follow the forums time to time to check if someone makes a ROM for your PDA. Basic problem is unlike most of the PDAs, your PDA is a non-HTC based PDA. I hope this helps. You can still download some PDA software to use your device more efficiently (Most of the PDA softwares are designed for working on both WM5 and WM6, since your device uses WM5, you won't be having a problem.).
Details of your PDA: (http://www.pdadb.net/index.php?m=specs&id=587&view=1)
Unoffical ROM forum: (http://forum.xda-developers.com/showthread.php?t=349007)
Offical ROM website: (https://www.imate.com/Support_DeviceSupport.aspx?key=48fc9a97-1b91-4350-919d-b4dfdbcb6cbd&cmd=roms)
Apr 18, 2009 | i-mate JAQ Pocket PC
HTC Touch was stucked up after an error while upgrading to WM 6.1
i think u have tried to upgrade thru custom rom bcoz this pda came with WM 6 only so u tried to upgrade to 6.1 thru custom rom procedure and it seems like something went wrong and u get a boot loader screen tri color with code written SPL 1.XXX on it dont worry i can help u in this go step by step as soon as ur problem is resolved leave other step
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then try this
download Hard SPL 3.1 from here
http://forum.xda-developers.com/showthread.php?t=445666
install it as described in the instructions inside the zip file
and then Rom Lite version for ELF from here
http://forum.xda-developers.com/showthread.php?t=451100
first install hard spl 3.1 as directed on ur pda and then update to custom rom from the the file downloaded
pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
Changing the language
Hi, Pocket PC's have Windows OS installed on them. As with computers, you woun't find any option to change the language of the operating system. Your computer comes with english Windows, and however you try, it woun't be an option to change the language of the whole OS. It is the same with PDA's. But even harder than that, each PDA comes with a specific Windows, altrought it is the same version to other PDA's it has some specific things to each model. You can't install a Windows made for HP Ipaq to a Dell PDA because it will simply not work. Also, the language wich is skipped with a PDA is not to be changed. The producing company will consider this ilegal in some cases. I don't know why but they simply woun't want to change the language for you. However, there some triks to do that your self. To change a language means to change the whole operating system installed in the ROM memory. But like I said, the producers woun't simply allow that, and when you will try to install a diferent language ROM on the PDA it will give you some errors. I know of some ways to deal with this, but it works only for HP PDA's. It will be risky to try it on your own PDA. Also it is a fairly complicated process, involving hexazecimal editing and decompiling a ROM image. The simplest thing you can do is to go to a service center (other that viewsonic's one or major service facilities) and ask them to do that for you.
Mar 04, 2007 | ViewSonic V35 Pocket PC
Windows Mobile 2003 SE Kernel ROM update error
I have already updated my e800 with Windows Mobile 2003 SE. I have had just a small communication problem between the notebook and PDA but there was no problem with update installation itself. If no one can help you try to contact hotline or service partner in your country. I hope that they can give you a proper answer why this error occurs.
Sep 08, 2005 | Toshiba e830 Pocket PC
Sep 08, 2005 | Toshiba e805
Sep 08, 2005 | Toshiba e805 Pocket PC
Sep 08, 2005 | Toshiba e800 Pocket PC
Toshiba e830 Pocket PC Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
