Question about Amana ALG331RAW Gas Dryer
Amana gas dryer mod#dlg33oraw,i have drum out change the gas coils,dryer glows for a few minunts the gas ignited then the flame goes out.It only stays lit for a few sec.HELP!
  • billiotv Aug 28, 2008
    check the thermal fuse it check good.Ijump the wire from the flame sensor,igniter glowed but ther wasn't no flame.amana gas dryer mod#dlg33oraw ,chang the gas coils igniter glows gets a flame for a few sec.then goes out.
    Master:
  • 521 Answers
Check out this link for more detailed help
www.applianceaid.com
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat
  1. A common way to "light" a dryer pilot light flame
  2. Dryer is running but will not heat, what could it be?
  3. Dryer tip 1 - Dryer tip 2 - Dryer tip 3
  4. How do dryer thermostats work ?
  5. How to connect - install a flex connector
  6. I am getting a funny smell in my gas dryer and clothes
  7. I need some help with the pilot light on my older gas dryer or the pilot light keeps going out
  8. Meter testing tips
  9. Whirlpool, Kenmore "Even Heat" gas dryer motor problems
  10. Whirlpool, Kenmore only gas dryer common trouble maker for no heat
Gas dryer with no heat: The parts that I have pointed out with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arc where they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Does the igniter get red and stay red, or does it get red, you hear a click and it goes off, then a minute later its gets red again?....if so you possibly have a bad set of coil valves. If the igniter gets red and stays red constantly then its the flame switch that is bad and maybe welded closed.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time. Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins). http://www.applianceaid.com/gas_dryer.html
Posted on Aug 28, 2008
  • Amana Master
  • 19,396 Answers
The problem is either flame sensor or gas valve. Fixing this can make appliance unsafe if you do not do the job properly.
  • 199 Answers
Here is a step by step procedure on checking your gas dryer. Parts location and replacements may be viewed from here
Course of action then would involve checking:
  • Thermostats or Thermal fuse;
  • Flame sensor;
  • different switches in the controller board.
Good luck.
    Brigadier General:
  • 6,966 Answers
Does the drum even turn? it might be auto stopping to prevent further damage if the drum is not turning.
Additionally, there are two (2) versions of this model (Amana DLG330RAW), pls confirm whether you have the PDLG330RAW or the PDLG330RAW1.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 848 Answers
Check the thermal fuse ........
My Amana DLG330RAW igniter glows orange and a flame is produced initally when starting the dryer but after the flame goes out when the igniter glows orange again (shorter glow time) a flame never occurs...
could have bad gas coils? part 279834 they're located on the top of the gas valve unplug dryer,remove the two pillips screws,lift up the cover and change out the coils,watch out on the three prong coil there's a spacer that you want to stay on the post so when you slide the new coil on the coil it's tight,if the spacer isn't on the post after you remove the old coil look in the old coil and stick anything that will fit and push out the spacer then slide it back on post then install your new coils.also while you're in there get a shop vac and vac up all the lint you see,remove the lint filter and then remove the duct that the filter slides down into and clean that,then set the vac up to blow and blow all the lint from the back forwards and vac that up,make sure you blow the motor off and the gas tube and parts,you should do this at least once a year with gas so you don't have a fire,then go outside and make sure the duct is clear no cages or anything on it,go back inside and remove the vent line from the back of dryer,if it's a long run you can stick a leaf blower into the vent line and blow it out.if you need anymore help let me know.
Oct 12, 2011 | Amana DLG330RAW Gas Dryer
I have an Amana gas dryer that doesn't ignite.
The most common failure when the igniter glows yet DOES NOT GO OFF followed by the flame is a defective flame sersor
this is what the flame sensor looks likeoldtech2332_46.jpgIt is attached to the outside of the burner tube,
Their are basically 2 types of those,1 that attaches to right side of burner cone and 1 that attaches to left..to order correct one what ya need is the model number which is typically on a label on the inside of the door on the rim of the drum opening
Just to be sure before replacing it,is that what your experiencing..that the igniter glows yet does not go off? if yes that pretty much sums up what your experiencing go ahead replace that flame switch.
If igniter do go off but no flame the problem will be with the gas valve coils
GENE
Aug 23, 2011 | Amana Dryers
I have an Amana dryer Mod. ALG649RAW. Turn dryer on ignites than flames, but after a few minutes goes out, it will again ignite, but won't flame. Is it overheating? The dryer is vented underground about...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | Amana Dryers
Model LG8219W2 On initial start up igniter turns on and flame is ok, after heats up and cycles the flame does not reignite,I can see the igniter glow red but flame does not return. the igniter contiues...
HI. This will essentially be an issue that concerns the gas valve coils. With that said, I will post below a complete burner assembly procedure that will help you isolate the culprit. I'm sure that the coils will fail the test, but to be safe, follow the procedure to confirm.
Gas valve/Burner testing procedure:
On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will have no heat.
The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.
If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
Click Here to access a exploded diagram of the burner assembly. The affected coils will be labeled number 15 and 10. The actual coil and valve assembly will be labeled number 11 and the burner will be labeled number 9
Aug 22, 2010 | Amana NED7200TW Electric Dryer
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
Apr 20, 2010 | Dryers
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
Amana ALG331RAW Gas Dryer Logo
385 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
