Question about Pentax Optio 555 Digital Camera
Focus problem with optio555
I recently bought an optio555, and I'm a little dissapointed with the quality of the focus. Especially pictures at range infinity seem slightly out of focus; objects at a smaller distance (< 5 meters) are usually OK. Apart from that, objects at the left of a picture are much 'less sharp' than objects in the middle. As I'm not sure what the 555 is capable of, I was wondering if I have a defective camera, or too high expectations
    Master:
  • 542 Answers
Sorry to say but looks like a mid-aligned sensor. Better go for an exchange - mine is pretty sharp at the edges....
Posted on Sep 08, 2005
    Master:
  • 542 Answers
I think you have a defective camera. I have the 555 and none of my pictures ever look out of focus like that. Especially since those are outside with lots of light. They should be crystal clear. The colors don't look too goood either. Have you just taken it in P mode and let the camera choose all the settings? Have you possibly set some settings that have changed what the camera came with?Something is not right.
SOURCE:
Sharp TV slightly out of focus
so not focus on out side please focus on write side http://specialneedsplanning.net/
Mar 18, 2013 | Televison & Video
Hi, I have a issue with the quality of the pictures I've taken recently on my Z2, the pictures a blurry around the edges. The centre of the photo is sharp. Do you have any suggestions please of what to do,...
This is due to settings change
Please switch the focus mode to multi point focus or any other
current setting will be center focus or spot focus that is why only the center is focused and the rest is blurry
Please refer to your fuji manual for instructions on how to change the focus mode
Thanx and i hope this solves your problem
Please dont forget to rate this information
Jul 17, 2009 | Fuji FinePix Z2 Digital Camera
What is the solution
You are dealing with "depth of field", or simply put (?), the range from near to far of an image that appears in focus. To increase the depth of focus, the camera must be set to a smaller aperture (higher numbered). Using a wider angle lens helps also. Focusing on the mid-point (near to far range) will also increase the apparent focus range. This is one of the most complicated photographic issues, and much has been written about it. Google "depth of field" for about 4 million explanations.
May 26, 2009 | Nikon D60 Digital Camera
Poor pictre quality
This set has 3 CRT's (picture tubes)
Remove the back bottom cover
Clean the CRT's with windex and a soft cloth.
(Find the Screen/Focus block)----Remove front grill cover and panel which covers the Screen/focus block.
Cover 2 crt's and adjust the focus control for remaining crt---(using the convergence pattern in the menu for the set)
adjust for the best focus.
cover that crt and move on to the next crt using the same procedure.
After setting the focus on all 3 tube's you will have the best focus possible for this set. If picture is still bad, you have bad crt's and the set is junk.
Cost to replace the CRT's is enormous!
Craig
May 08, 2009 | Televison & Video
Picture in View Finder perfectly clear, but out of focus
I would check IS(image stablization) setting and continous shooting setting to make sure these features are turned off. You want to experiment with different IS settings and definitely turn the continous shooting mode because the continouse mode may not focus 100% in order to shoot multiple shots. Hope this helps. -James. P.S. In my case it was too difficult to distinguish the quality of focus in the VF or LCD so you may not see the focus issue on them.
Apr 12, 2009 | Canon PowerShot S3 IS Digital Camera
Focus
The little white ring on around the lense, that is the focus on the camera. Now the other issue with picture quality is the camera itself. I believe this camera only 1.3 mega pixels to get a less blurry higher quality pic u should use a higher mega pixel camera
Nov 12, 2008 | Logitech Quickcam Chat Webcam
Absolutely screwed up, recently purchased camera
try to shoot without a card. or better use a known good card. [:0)
Jan 10, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Unsure of how to use the extra functionality
That is the focusing ring. I'm guessing your camera is set to focus automatically (Little switch on the side of the lens should have settings for either AF or MF, or something similar.)
If its on AF, you don't need to adjust the focus ring.
However, if you have problems with the AF (sometimes it has trouble, especially in low light) you can switch it to MF, and focus manually by changing the ring.
As a general guideline, the more you twist to towards macro, it focuses closer and closer, and infinity futher away (if you're taking a shot of the moon, you want it on infinity)
Nov 26, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Poor exposure when using the flash
I read in another Toshiba forum where some users were putting a small piece of electriacal (black) tape over the flash sensor, and their indoor photos with flash turned out spectacular, since it allows the camera to apply more light . Actually fools the camera but it works. You might want to experiment with it..
Sep 15, 2005 | Toshiba PDR-M700 Digital Camera
Pentax Optio 555 Digital Camera Logo
59 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
