I am trying to open a floppy disc and it won't open.Disc drive is installed ok and operating.Haven't used this part of computer before can you tell me what I might be doing wrong
    Sergeant:
  • 241 Answers
Sure
>does the drive appear in "My Computer"
>if Yes right click on it and see if you have it enabled
>If yes when you put a floppy in does the light flash or can you hear any sound from the floppy drive
> if yes try a different floppy
> still not working
> Control Panel+performance maintenace+ system+device manager+hardware
>click on disk drives and see if the floppy drive is there
>if yes select the general tab and see if it is enabled.
I hope this will help
Thanks
Posted on Aug 28, 2008
Why won't my packard bell's cd disc or floppy disc drive won't open
CD / DVD and most optical drives - Manual eject by sticking a straightened paperclip in the tiny hole and gently push open.
Apr 02, 2013 | Packard Bell Computers & Internet
Xbox 360 hard drive won't format, Some please
Try using your pc to format x box by hooking it with a usb cable.
Open windows and right click my computer.Then click manage,select disc managment under storage heading.Wait for the window to load.
Then look for unknown or not initialized disc.Right click left square area then click initialize disc.
Select mbr then ok.Windows should lable the disc unallocated.
Then right click the right rectanguler area of the x box hard drive and click new partition.Or format.
Sep 30, 2011 | Video Game Consoles & Games
How to format a disk
Instructions
  1. Formatting and Installing from the Windows XP CD
    • 1 This section explains how to reformat a drive from the Windows XP installation CD. This can be used when installing a fresh copy of Windows onto a computer. Here it is especially important to backup all of your important information because upon formatting you will lose EVERYTHING that used to be on the drive. This includes all applications and device drivers, so you must back up everything you can.
    • 2 Insert your Windows XP installation disc into your CD drive (Home or Pro--it does not matter).
    • 3 Now as you computer boots a little more it will say "Press any key to boot from CD.." press a key to do so.
    • 4 The CD will load up a blue screen and then spend a while loading files it needs. When it is finished it will list a few options, mainly "Press ENTER to set up Windows XP." Press Enter or Return.
    • 5 Now you will be at a screen to select where to install Windows to. This is where you can delete old partitions and format drives. The box in the bottom half of the screen shows all your drives and the partitions that exist on them. Use the Up and Down arrow keys to highlight your "C:" partition and press the 'D' key (if all that shows up is "Unpartitioned space" and you have no C: or D: partitions, skip this step). On the next screen press the 'L' key to finalize deleting the partition.
    • 6 Now you are back on the screen to choose where to install Windows. The box on the lower half of the screen should no longer show a partition but simply have an entry "Unpartitioned space xxxxxMB." Select this with the arrow keys and press the 'C' key to create a partition on the drive. The next screen tells you the minimum and maximum sizes the partition can be and lets you pick the size. The default size is the maximum, but double check that the number entered is the maximum and hit enter.
    • 7 Now you will again be back at the choose where to install Windows screen. But this time you will have a partition that looks something like this "C: Partition1 [New (Raw)]xxxxxxMB." Highlight this entry and press enter.
    • 8 The next screen lets you choose which file system to format the drive with. Choose NTFS as it is faster and more secure. If the drive is brand new and has never been used before then use one of the options that ends in "(Quick)." Or, choose one of the lower down options. Use the arrow keys to select the proper one and press Enter or Return.
    • 9 From here you are all set and the installation of Windows will proceed starting with a format of your drive. This will take a while (over half an hour) so you can take a little break.
How to Format a Floppy Disk
Instructions Things You'll Need
  • Floppy Disk Drive
  • Floppy Disks
    • 1 Insert a floppy disk into the floppy disk drive.
    • 2 Double-click the My Computer icon.
    • 3 Right-click the icon for the floppy disk drive, usually labeled 3 1/2 Floppy (A:).
    • 4 Choose Format from the menu that appears.
    • 5 Click Start.
Format a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
Aug 08, 2011 | Computers & Internet
Softwear Instalion
what problem are your experiencing?and what software are you trying to install?Please specify the problem and software so we can give you the solution//
Jun 27, 2011 | Computers & Internet
I bought a new hardrive for my m2000 and when i load it it is giving me a "media test failure" response..... how do i load it properly?
If you bought a new hard drive (meaning the internal hard disk), it won't have anything on it. If you just install it and try booting your computer, there won't be an operating system to load. The BIOS (the operating system built into the motherboard) is set up to try loading the operating from connected devices in a certain order. Usually it tries the optical drive first, then the hard drive, and finally it tries to boot over a network connection. The media test failure message means it tried that last resort and still didn't find an operating system, and it's telling you that maybe you have a bad network cable.
You'll need to reinstall your operating system and applications so that the computer will start normally. If your computer came with a restore disc set, or you made a set yourself, you'd use those. If you don't have restore discs, you can do a fresh installation of Windows from CD. You need to find the disc for the version that came installed on your computer, since you'll need to use the product key from the sticker on the bottom. Drivers and utility programs you can download from Compaq's (HP, actually) support and drivers website.
Once you've got a bootable Windows system on the new drive, you won't get that strange message any more.
Jun 03, 2011 | Compaq Presario M2000 Notebook
Hello, I needed to replace the 400 Gig hard drive but could only find a matching 320 Gig at the Gateway site, I installed it and my monitor stays black no boot up , I purchased a Spotmau PowerSuite 2010...
The drive should have came with a boot disc. If not re-install a the 400 gig drive and go to last known good configuration.
For Vista:
?id=microsoft.windows.resources.expandarrow To access the System Recovery Options menu
If you have a Windows installation disc:
  1. Insert the installation disc.
  2. Restart your computer.
    Click the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, click the arrow next to the Lock button ?id=eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c, and then click Restart.
  3. If prompted, press any key to start Windows from the installation disc. If your computer is not configured to start from a CD or DVD, check the information that came with your computer.
  4. Choose your language settings, and then click Next.
  5. Click Repair your computer.
  6. Select the operating system you want to repair, and then click Next.
  7. On the System Recovery Options menu, click a tool to open it.
If your computer has preinstalled recovery options:
  1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
  2. Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
  3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER.
  4. Select a keyboard layout, and then click Next.
  5. Select a user name and enter the password, and then click OK.
  6. On the System Recovery Options menu, click a tool to open it.
Nov 28, 2010 | Gateway GT5654 Desktop PC
Where is the insert for the floppy disc
The floppy disk may or may not be installed in section 5. They started eliminating floppy drives some years ago, when USB flash started to become popular.
5
FlexBay drive panel
Can contain an optional floppy drive or optional Media Card Reader. For information on using the Media Card Reader, see Using a Media Card Reader (Optional).
If your question was more basic than this, and you have a floppy drive, then you just insert the floppy into the slot. It doesn't open. Look for the arrow on the floppy disk, if it doesn't go in one way, turn it over.
Sep 13, 2009 | Dell Inspiron 531s Desktop Computer
F1 floopy diskette faliure seek faliure
Make sure it is not disabled in the boot order, there is also an option for the drive itself (Diskette Drive) that must be disabled
Jan 05, 2009 | Dell Dimension E310 PC Desktop
Nexxtech External Floppy Driver Problem
Normally windows will install any driver for a usb floppy drive automatically. If it needs one. I'm surprised that it hasn't just worked by plugging it in as there cheap floppy drives over purchased have all just worked without the need to install drivers on win xp and higher. Remember you won't see the drive appear under my computer until it has a disc inserted in it though.
Jul 17, 2017 | NexxTech USB External Floppy Drive (NEFD2)...
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
