Question about Pentax Optio E40 Digital Camera
Battery power my camera seems to be flattening any battery I put in it I have tried both alkaline and lithium and within hours the batteries are flat what could be causing this
  • 1 more comment
  • Anonymous Dec 31, 2008
    My camera doesn't hold a battery without saying battery depleated.
  • saxenavikram Jan 20, 2009
    my battery does not last for long time for newer one also hardly 20 min
  • larapentax Feb 10, 2009
    I have the same problem - it keeps saying "battery depleted" even though they are brand new batteries. I;m not sure it is dirty points.
    Master:
  • 848 Answers
Just check the contacts in your camera where battery is placed it must be dusty so try to clean it up .
Posted on Aug 28, 2008
My camera is showing battery exhausted when i turn on the nikon camera i purchased a new battery and am still getting the same problem
You can try using Lithium batteries (Energizer Ultimate Lithium) instead of an alkaline battery. If you are using brand new, high-power batteries and are still getting this message, there may be a short or some defect within the camera itself that is causing the batteries to drain unnecessarily fast.
Mar 12, 2011 | Nikon Coolpix 3200 Digital Camera
Toshiba PDR-3300 Digital Camera
Hi this is common problem if your sure that these batterys are new and you have used that make and type of battery before than the problem will be on the board of the camera itself.
If these batterys are ones you have not used in your camera before then the chances are these batterys are just not powerfull enough so you can by a recharge pack for your camera ok so let me know if its new batterys and if you have used this type before.
Also insted of using the lcd can you turn the screen of then try taking picture using normal view finder as you would on a none digital cam
It could just be that the batterys you brought are faulty and might be worth trying another set before giving up.
These camera usuall wont switch on with normal batterys so just try another set or if you have let me know.
If the battery says low bat then goes off then these batterys will not work if tryed again but if you can get camera on turn off the screen then try taking picture ok get back to me and let me know ok
Apr 06, 2008 | Toshiba PDR-3300 Digital Camera
Have a nikon D80, sometimes when turning on and taking a photo the battery drains to no charge. have to turn off and back on again and camera works ok. have tried on existing battery and on a brand new...
HI,
You can try updating the firmware if it is possible first.If this doesn't help then try removing the batteries off the camera and allow the camera to reset for an hour and then put them back.
If this doesn't help then You need to use 2500 or higher rechargeable batteries - as soon as you switch to this type of battery, it will work fine!
Your camera requires four AA size batteries.There are several factors that contribute to battery life:
NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges).
Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting.
Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed.
Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries.
Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Goodluck,
Please don't forget to rate the solution as fixya..
Apr 08, 2008 | Cameras
Mv500 camera batteries run down fast
you need some new acumulators or alkaline batteries
Oct 27, 2009 | Microtek Take-it MV500 Digital Camera
Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
Apr 02, 2009 | Canon PowerShot A630 Digital Camera
Camera turns on and straight of again
It may be that your batteries are flat. If you are using alkaline AA batteries, try NiMH rechargeable or Lithium disposable batteries, as the battery life can be extremely poor with alkaline batteries. Some cameras won't even work reliably with new alkalines.
Otherwise, it could be faulty, and will need professional repair.
Sep 05, 2008 | Cameras
Batteries
USE LITHIUM BATTERIES
Oct 11, 2007 | Gateway DC-M40 Digital Camera
Choosing batteries
Your camera requires four AA size batteries. There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the Display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may vary based on the Alkaline batteries selected. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Choosing Batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Pentax Optio E40 Digital Camera Logo
60 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
