Question about Amana Refrigerators
I have an Amana SRDE528TB W side by side fridge freezer made in 1999. When the compressor kicks in it trips out the house RCD circuit All the other electrical bits appear to function OK and the problem only happens when we hear the compressor start... a fraction of a second later the RCD circuit trips out. This is a recent problem I'd appreciate any comments and also source of spares and/or engineer if this is not a DIY job Thanks
  • ProfRPT Aug 29, 2008
    An update on the above post.....the SRDE528TB W doesnt trip when turned on now....stays on for several hours with compresor running, and gets cold, and trips RDC circuit when compressor turns off...any comments welcome!
    Scholar:
  • 62 Answers
Sorry to say that the most likely cause of this problem is a bad compressor. Many Amana's have the same problem. In dealing with these units I find that will run for a while then have trouble starting up. In your case you are using a ground fault circuit and the extra current draw is causing the house breaker to trip, although most manufactures suggest that you don't use that type of circuit. The only real way to correct the problem is to replace the compressor, or get another refrigerator. The compressor replacement should be done by a qualified technician.
Posted on Aug 30, 2008
Many thanks for your response...I had originally come to the same conclusion. However, since my last post I have removed the RDC from my main circuit board and replaced with a double pole switch....the fridge now appears to work fine and none of the MCBs trip...keeping my fingers crossed!
Hope this may help others with the same problem as the switch cost £10 and was replaced in 20mins...rather less than a compresor or fnew ridge which was my immediate thought
Posted on Aug 31, 2008
I have a Bosch kfu5755/21 fridge freezer and it keeps tripping the rcd when I turn it on
Lee,
Most likely to be the defrost element which is located in the freezer.
Disconnect your appliance from the mains power supply
If you empty the bottom of the freezer and remove the drawers and shelves you should be able to locate screws to remove the rear panel. When you get this panel removed you should expose the evaporator.
26262363-xienn535tbiydys4e5iqbku3-5-0.jpg It is similar to the one above.
On your fridge the defrost element clips onto the bottom of the evaporator. If you follow the wires going to this element and disconnect both ends, your fridge will work untill you get a replacement part.
With the element disconnected and your fridge does not trip the rcd order the part from the link below.
https://images-na.ssl-images-amazon.com/images/I/51eg7ZfxJVL._SX522_.jpg
Aug 19, 2016 | Bosch Refrigerators
An Amana fridge SRD520TW has started tripping the house's main circuit board.
The start capacitor on the compressor may have failed. There is a chance that a defrost heater element has shorted to a metal part of the fridge.
Aug 13, 2016 | Amana Refrigerators
Find out why my freezer is shorting
Is your FREEZER is plugged into a wall socket which is protected by an EARTH LEAKAGE UNIT or RCD [Residual Current Device] ???
Most manufacturers advise NOT to have this type of appliance connected through an RCD as the start load required when the COMPRESSOR "kicks in" is quite large [especially in larger fridge/freezer units] AND will quite often TRIP your RCD. These appliances are better connected to a separate electrical circuit if at all possible and not protected by an RCD.
Sep 20, 2014 | Refrigerators
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
Rcd tripping
Either the start relay in the compressor is grounding electrically or the defrost heater is (most likely start relay). To replace this yourself is difficult as it requires technical knowledge. If you are located in California, bay area I could help you personally
Apr 21, 2014 | GE Profile PSW26P Stainless Steel Side by...
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
Main residual circuit breaker trips fridge approximately every 12 hours
normal fridge takes 7- 12 amps to start, if after 12 hours it trips i would lean towards a compressor issue. once it heats up the comp. may draw alot of amps causing it to trip. is it the only item on that circut? does it still trip being alone on the circut?
Apr 06, 2014 | Admiral 26 cu. ft. Side-By-Side...
Amana fridge/freezer compressor problem
Unplug unit.
It's not possible to tell which without replacing the starting system. Hard start kit would be fine. RCO410 is common. If it starts the unit the next check would be an ampmeter clamped onto one of the power leads. The ampmeter for refrigerators of that age may read around 2-5 amps when running. If it's much higher than 5 Amps after it's running be prepared to replace the compressor. Maybe it won't quit today...but it won't last with high amperage. If it doesn't start with this kit you need compressor.
Sep 08, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana sxd524v fridge-freezer tripped out the power
Hi, you can check if there is a fanmotor on the condenser section and make sure that it is working. Second, you can try replacing the starter relay which you will find in the connection area of the compressor. If this does not work, I am afraid you would have to have the compressor replaced.
Mar 13, 2009 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
482 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
