Question about Microsoft Windows Vista Ultimate Edition
Problem my status bar not working on windows vista
  • liel_h2 Jan 09, 2009
    i cant install the printer lexmark 8300, i have windows
    vista...
Sound drivers are not installed.it shows a DLL problem
Posted on Aug 31, 2008
Hello why does my lg g vista showing a red x in the connection status bar
This would imply that you don't have any connection to make calls or text... try to ensure you have inserted your SIM Card correctly and perhaps to move out of the building you are in until you find a place with better coverage. When this happens you will have at least one white bar in the status bar. You will be able to text/call. This will not affect your internet/data. Hope I helped! :)
(also I hope you are talking about the LG L Vista and no the OS Windows Vista)
"1. Celllular Signal Strength" is what the status bar is. It should be all white. lg-g-vista-showing-red-x-in-connection-b3zxdb2pol302lkrtsslmkro-2-0.png
Feb 17, 2016 | Computers & Internet
File: \Windows\system32\ntkrnlpa.exe. status: 0xc0000098 windows failed to load and no recovery disk
Running the Windows Memory Diagnostic Tool
If Startup Repair is unable to get your system running again, and if neither System Restore nor Windows Complete PC Restore has returned your computer to a condition of reliable health, consider the possibility that you have failing memory. To test this hypothesis, click Windows Memory Diagnostic Tool in the Startup Recovery Options menu. The Windows Memory Diagnostic Tool will ask whether you want to restart now and check for problems (the recommended option) or check instead on your next startup. Because you're having trouble getting to that next startup, you presumably want the first option. For more information on this you can refer the link below.
Make system repairs from the Windows Recovery Environment
http://windows.microsoft.com/en-US/windows-vista/Make-system-repairs-from-the-Windows-Recovery-Environment-from-Windows-Vista-Inside-Out
Run check disk command from Windows Recovery environment to fix bad sector on your hard drive
a) Insert the Vista DVD, and boot from the DVD.
b) As you want to boot the computer from the Windows Vista DVD, you need to press a key, on your keyboard when you see the prompt. You should now see a black screen with a white status bar at the bottom stating Windows is loading files.... After a while, the status bar will turn completely white and you will see a screen stating that Windows is loading. The Windows Setup environment will continue to load and when finished you will be presented with a screen that prompts you for information about your location and language.
c) At this screen you should configure the Language to install, Time and currency format, and Keyboard or input method options so that they are set correctly. When done, press the Next button. You will now be at the main Windows Vista setup screen where you would normally install Vista on to a computer.
d) As we want to repair the computer, you should click on the Repair your computer option. This will bring you to a new screen where the repair process will look for all Windows Vista installations on your computer. When done you will be presented with the System Recovery Options dialog box
e) Select the Vista installation you would like to repair
f) From the system recovery options, choose command prompt and enter the command chkdsk /r.
For both the above steps you can refer the link mentioned below.
http://windowshelp.microsoft.com/Windows/en-US/Help/95b4c03a-ac42-49a4-a90d-8f3736a995271033.mspx
Jun 13, 2011 | Dell Computers & Internet
Scroll bar disappeared in Windows Vista e-mail
1. click on the 'Tools' menu then the 'Options' option.
2. click on the 'View' tab.
3. - in 'Window Options' section, ensure that the 'Horizontal
scroll bar' and 'Vertical scroll bar' options are selected.
-- PowerPoint - in the 'Show' section, ensure that the 'Status bar'
and 'Vertical ruler' are selected.
4. click OK.
Jan 28, 2010 | Microsoft Windows Vista Home Premium...
Hp cue status root has stopped working
click on the start button go to start search bar and type services.msc and hit enter now a window will open look for hp cue in that and check status it should be started and automatic not mannual or automatic delayed if its started then there is a problem with the cue version of the hp software
now try downloading the driver through the link and reinstall the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3311800&lc=en&cc=us&dlc=en〈=en&cc=us
Jul 10, 2009 | HP Deskjet D1455 InkJet Printer
Vista keeps using the internet connection
The greedy folks at Microsoft use their WGA (Windows Genuine Advantage) to monitor your microsoft products, cant be helped, they claim to only check microsoft products though this should only take a second or two for verification. Check your firewall settings and if neccessary use multiple firewalls to stop the intrusions.
Ed Meyer
Owner
AACS
www.alwaysaffordablesolutions.com
May 22, 2009 | Microsoft Windows Vista Home Premium...
Status bar (that shows sum of highlighted cells) has vanished
The status bar is located at the bottom of the Excel window. It is to the left of the View buttons. If you right click, a customixe status bar menu appears and you can select what you want to show. If is does not come up, you should run Microsoft Office Diagnostics located under the Office tools menu.
Mar 22, 2009 | Microsoft Excel for PC
When we will open the page they don't show the task bar in down
What program are working with, can you tell me?
If it is Internet Explorer, the bar in the bottom is status bar.
It's at the
Main menu - View - Status Bar
make sure it is checked...
Good Luck :)
Feb 19, 2009 | Microsoft Windows XP Home Edition
Status Box Remains at 99%
Try uninstalling then re-installing the drivers. Also if you are using Windows Vista you may need to go to the printer manufacturers website and download Vista drivers if you are running XP drivers for the printer.
Nov 24, 2007 | IBM Lexmark Z715 InkJet Printer
Microsoft Windows Vista Ultimate Edition Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
