Question about Siemens Euroset 2005 Corded Phone
Euroset 2005 phone does not have high low volume switch
    New Friend:
Ya you are write the volume switch is not given in Euroset 2005. volume can be adjusted by this code while u pick up the receiver "Set/mute # 4 #"
M.Qasim
Posted on Aug 10, 2011
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
He is quite right but with a slight correction in the code
First lift the hanset then press 'set/mute ' x then set
Where X= 1 to 9 no on the keypad corresponding to volume
If you press 0 then the next call will be mute but after u lift the handset it is reset to normal
Default factory setting is 6
Posted on Oct 15, 2012
SOURCE:
How can I set a speed dial on SIEMENS: EUROSET 2015?
Lift the handset
Press the set key
Press the repertory key (under which speed dial button like to store)
Enter the number
Again press the set key
Mar 05, 2014 | Siemens Euroset 2015 Corded Phone
Does the Siemens Euroset 805 have a high low volume switch ?
Thanks M.Qasim for the solution!
Just a small correction you have to set the phone while is ringing. I did the following sequence call to the pone then press "Set" "#" "4" "#"
Oct 28, 2012 | Siemens Euroset 2005 Corded Phone
Very low dialing town and reception in euroset 802
1) you must shure that you some distant near from the base
2) change channel for better reception
3) adjust the volume.
4) try to put the phone in another jack box, if the problem persist, the problem is with the company supplier.Remember to get charged full batteries. or are defective replaced.
God bless you
Jul 31, 2012 | Lands Phones
How do i change ringer tone and adjustment of Euroset 2005 Corded Phone
How to Change the ring tone of the Phone - "Siemens Euroset 2005"
1st - Lift the Telephone receiver
2nd - Press Set/Mute
3rd - Press # and any number 1 to 9 and then Press #
4th - Place the Telephone receiver in its normal Position.
That's it now you should have changed your ring tone of "Siemens Euroset 2005"
Thanks Enjoy
Jun 23, 2011 | Siemens Euroset 2005 Corded Phone
Ringer High Low Switch Not Avalable
My Dea :Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
May 06, 2011 | Siemens Euroset 2005 Corded Phone
Can't get CLI to work on 5020
With the handpiece on the hook. Try typing #86 into the handset. This should turn on CLI from that handset.
Sep 13, 2009 | Siemens Euroset 5010 Corded Phone
Siemens euroset 4005. Cannot unlock phone
Man that's BAD! It's basically the phone problem...U can either change your phone or contact your phone service provider see if they can help u with the code.
Jun 02, 2009 | Siemens Euroset 2005 Corded Phone
Siemens Euroset 2005 Corded Phone Logo
6,240 people viewed this question
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
