Question about Panasonic ET-LAM1 Projector Lamp for PT-LM1
How to reset lamp hour of panasonic pt lam1 lamp
  • Panasonic Master
  • 6,694 Answers
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Posted on Jul 18, 2011
SOURCE:
How do you reset the lamp hours on a Panasonic PT-61LCX66-K
There probably is a service manual you can find on line to help you with how to reset the lamp hours.
http://www.manualowl.com/m/Panasonic/PT52LCX66/Manual/289575
Nov 11, 2014 | Panasonic Televison & Video
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
How to rest alamp hour on panasonic tv with a universl remote model pt 432-c14
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Panasonic ET-LAM1 Projector Lamp for...
How to reset lamp hour of panasonic pt d6000se lamp
the lamp hour timer on the lamp housing, you can replace a new timer,
Apr 19, 2014 | Panasonic ET-LAM1 Projector Lamp for...
Reset lamp for Panasonic PT-vx400
There should be a menu that goes across the top listing video, audio, setup, projection....etc. Either under setup or advanced there will be a drop down menu with lamp settings under it. Under that menu will be a reset lamp or something as direct as lamp hours. That is where you can reset the lamp timer.
Feb 05, 2013 | Panasonic PT-VX400 Projector PT-VX400
RESET THE LAMP HOURS OF PT-LB60EA
Go to menu > option > lamp hours. Then press enter on the Lamp Hours for 5 seconds. A new option will pop out asking to reset lamp
Dec 14, 2011 | Panasonic Projector Lamp for PT-LB60,...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How do you reset lamp hours back to zero on a Panasonic PT-D4000U projector?
When you remove one of the lamps, you're notice that there's a micro-chip build into the housing itself. Unfortunately there's no way of manually resetting the lamp hours, due to the chip. You'll need to replace the whole lamp assembly.
Apr 13, 2009 | Panasonic PT-D4000U Projector
Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Feb 25, 2009 | Panasonic PT-L785U Multimedia Projector
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Panasonic ET-LAM1 Projector Lamp for PT-LM1 Logo
430 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
