Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Data not shows in a drive
Hello all
There are four partitions in my system, C, D, E and F drives. When I want to access my F drive nothing display in it, but if I am accessing the data through Nero it is accessed. Also in the property shows the disk space used 5.0 GB.
So please help me in this regard.
  • Anonymous Aug 28, 2008
    THE SAME PROBLEM
    Brigadier General:
  • 5,158 Answers
What brand is the hard drive ?
Posted on Aug 28, 2008
I bought new transcend store jet 500 gb but i cannot shrink its volume in windows 7
Creating partitions on USB drives is useful for larger drives or for keeping data organized.
It also allows one drive to be used for multiple purposes, such as having a partition to store data that is accessed often and another partition for backup.
With the new ReadyBoost feature of Microsoft Windows Vista and Windows 7 operating systems, as well as with various server operating systems, you can create a partition on many external drives to use for a virtual memory swap file location, speeding up the computer for many memory-intensive tasks or for systems that are short on RAM.
Back up any data currently located on the drive prior to creating, deleting or changing partition size or otherwise attempting to configure the USB drive.
Open "Computer Management" under the "Administrative Tools" section of the Control Panel. Click on "Disk Management" to display a list of drives and their current partitions.
Right-click on the drive and choose "Extend Volume" to make the partition larger using available space on the drive; "Shrink Volume" to reduce the size of the partition, freeing up space on the drive; or "Delete Partition" to remove all partition information and to create fresh partitions on the drive.
Right-click on the free space on the drive and choose "New Simple Volume" if the existing partition has been deleted.
Click "Next" and then enter the desired size of the first volume on this disk.
Choose to assign a drive letter, assign the partition to its own folder on an NTFS volume or not to assign a letter or assign the partition to a folder if the drive is going to be used on a different system.
Click "Next" to display the format dialog screen and choose to format the drive using the default settings.
Give the volume a name and click "Next" again to review all of the chosen settings.
Then click on "Finish" to begin the format process.
Repeat the partition creation steps for as many new partitions as are desired on the drive.
Hope this helps
Oct 30, 2012 | Transcend StoreJet Computers & Internet
Hi, i have an external hdd which had to partitions, but now it only displaying one drive as F: drive and when attempting to access it - unformatted error. I've tried chkdsk f:and it comes up with The type...
What are you trying to do or accomplish? Are you wanting to format it, access the data on it, or something else? Have you tried formattting it?
Does "to partitions" actually mean "2 partitions" or "two partitions" instead?
It might help if you stated how the drive got in that condition.
Sep 09, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Cannot access hard drive, USB port detects it, but does not access
You can verify what drive has been detected by your Operating System, which I assume is Windows of some sort by going to: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk will be displayed with all existing partitions.
I order to use any partitions in your new drive, you will need to assign a drive letter to each new partition.
If you have a brand new drive that is completely unformatted, then you will need, also via the context menu, Create partitions, Format partitions and assign a drive letter so that you can use the formatted partitions.
Hope it helps: let me know how you go!
Below is example of Disk Management display showing my external USB 300GB drive with _EXT disks & displayed context menu:
Jan 02, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
One of the two partition of the hard disk cannot be accessed
try disk repair.
start - run, type chkdsk d: /r
also try - chkdsk c: /r
Good luck
Apr 14, 2009 | Computers & Internet
Partition problem
In my humble opinion, the best option is to install a second (blank or larger) drive. Install some recovery software such as "easy recovery pro" or something that will be able to read files from a filesystem that has had the partition table written over. Start with trying to scan using FAT32, and in failing that, try NTFS. Restore the data to the second drive, format the first and partition as required. Copy the data back to the first drive to the partitions that you specified, and erase the data from the second drive. A free option may be pandora recovery, available at http://www.pandorarecovery.com/features/
Jan 20, 2009 | Microsoft Windows XP Professional
Partition Problem
Yuou must backup the data of d:\ in another harddrive or volume before doing this backup your data in another volume and then merge the data you can even copy the sectors from partion magic .Data can be recovered by using data recovery softwares.
Partition parameter
From the data you provided, the D drive is deleted and is newly created. But it is not yet formatted. So the data is virtually deleted. Why I said virtually is because, the data is still there on the drive physically and you can recover it using third party tools like OO disk recovery tool. That is why partition magic is still showing data on it.
And it is also obvious that the task which Partition Magic started (splitting drives) is not finished properly. That is why K partition is incorrectly formatted. It is natural that it asks format of D drive because D drive belongs to no file type and it must be of FAT32 or NTFS or other file system.
The solution for your problem is try recovering your data on D drive using disk recovery tools. Then format it using FAT32 or NTFS. Format K drive also in FAT32 or NTFS. Use either partition magic or Computer Management. Since already PM caused problems on your computer, try computer management. It is safe.
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
EISA configuration
I believe that he EISA configured partition is where your computer manufacturers 'Restore System' data is kept so that you can't normally access it and mess it up. You seem to have gone to a lot of trouble to do work around that.
I would be interested to know if you can still restore your system now using the data that you transferred to a different partition?
Nov 01, 2007 | Computers & Internet
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
59 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
