Question about Xerox DocuColor 12 Printer
NVM settings for Splash RIP
Hi I need to know the correct NVM read write settings please for the Splash G620 / G630 RIP - not the Fiery. THANKS
    New Friend:
I found all the correct settings here : http://thedigitalhut.net/device-not-responding-on-the-splash-g-640-and-xerox-docucolor-12/
Posted on Oct 28, 2013
2 Suggested Answers
  • 7 Answers
SOURCE: fiery rip not seeing dc12
Did u install start patch?
Posted on Jul 30, 2009
Patch installation sequence for the Fiery X12 with DC12. Hi, I had a problem with Rip and I installed the 1.5 system, but the system can not find the DC12, it says "Error network controller." I have...
You need install patch "1-56CTS.ps". Try to find it via web.
Also install Fiery Downloader app. Go to File->Download and choose file "1-56CTS.ps". Then reboot a fiery and problem must go away.
Oct 29, 2013 | Xerox DocuColor 12 Printer
Printer turn on??
hi,
may I know what exactly the unit the you have there.
also input some more info regarding your problem
thanks
Jun 26, 2009 | Xerox DocuColor 12 Color Copier
Xerox DCCS50 to DC12, change Cobra with X12 fiery
at the end of setting up network settings it should ask if you want to save settings, click yes then its enabled. i have never had a fiery that doesnt hold its settings so its probably something you arent pressing.
there is an issue with one of the mac OS's that it just doesnt like the old fiery rips and you will never be able to print, but i'm not that clued up on the mac side and cant remember, sorry.
from your add printer section it should automatically see the x12 and give you the options of a hold,print and direct queue. I f you havent got a pc then the only queues that is useful to you is direct. Print holds the job on the hard drive and will eventually fill the server
Jun 19, 2009 | Xerox DocuColor 12 Printer
Xerox DC12 Fiery EX12 Print missaligment
caopy can be set by NVm Code 720-001 for side A
720-002 for Side B
please note down initial values before changing it
Apr 21, 2009 | Xerox DocuColor 12 Color Copier
Dc 50 doesn't start
THE PROBLEM YOU ARE GETTING IS A BAD CONNECTION BETWEEN THE IOT-NVM RAM BOARD AND IOT-SYS BOARD (MAIN BOARD) , JUST UNPLUG IT AND PLUG IT BACK. IF DOES NOT WORK THE BATTERY WENT DEAD , YOU NEED TO REPROGRAM ALL 3 BOARDS NVM , IOT-SYS AND HALFTONE. I HAVE THE PWS STATION FOR REPROGRAMMING AND FIRMWARE UPDATES. THE P.C. BOARDS ARE LOCATED IN THE BACK OF THE MACHINE , JUST BELOW THE SCSII CONECTORS FOR THE FIERY OR SPLASH. HOPE THIS HELPS YOU. diesco_cxl@hotmail.com
Mar 15, 2009 | Xerox DocuColor 12 Printer
PROBLEMS WITH FIERY AND DC 12
sir u do first one thing
1,check cable betwen fiery & dc 12 machine
2, press 0 + start enter code 6789
3,go to nvm read/write
4,enter nvm 759-053 code -enter 1
5, next 759-054 code-enter 1
Dec 09, 2008 | Xerox DocuColor 12 Printer
Printing to an LC031
The mini centronix port is used to update your fiery. You need to set up an IP address, Subnet address, and gateway on the fiery. Then go to WWW.lanier.com, and download the LC031 print driver, or E7000 fiery I believe. You may want to check the fiery model. Then is a matter of installing the driver, and pointing it to the IP address.
Dec 27, 2007 | Office Equipment & Supplies
Xerox DocuColor 12 Printer Logo
152 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
