Question about Cerwin Vega VE-28S Subwoofer
Crackling my sub works fine but it has a crackling sound that doesnt go away unless you turn it off for some time, when i turn it back on it will start crackling again soon after even when it's in standby mode. what causes the amp to do this and how do i find out which component to replaice to fix it?
Yeah, I've had two of these go out on me in exactly that failure mode. The first time, C-V bounced me around to two repair shops (a three-month process) before telling me to send it to them in Florida. This time, I went directly back to C-V with it, and they've had it two months now, and every time I call for a status update, I'm told "We'll let you know," or "We're working on the paperwork." Their service and support staff are not helpful - friendly, but not helpful - and the failure rate I've experienced is absolutely unforgivable.
So, my best solution I can give you is send it back for a warranty adjustment, and then sell it. As soon as mine comes back this 2nd time, it's going on the market, and I'm going out to buy a Sony.
Posted on Oct 10, 2008
My legacy 12 inch subs are making a crackling sound what can do?
Hi rodneybarton
The problem of your unit may be its amplifier. You need to open the box and inside of it, there is a component that attached on the heatsink you need to replace that one. or better send your unit to qualified technician.
Dec 29, 2013 | Jl Audio Car Audio & Video
Crackling subs
After crackling sound they stop and the light on overoald
Dec 29, 2013 | Legacy 12 500 watt l series woofers,...
Crackling
So if you bought enclosures that are premade AND had the speakers installed, you need to see if there is a cross over network installed in them
Apr 27, 2013 | Car Audio & Video
Tvee 20 subwoofer has distinct hum noise. Any advise?
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
May 29, 2011 | Boston Acoustics TVee Model Two TV...
Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
May 28, 2010 | JBL 5.1-Channel Home Theater Speaker...
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
Crackling coming from Velodyne DD-10 subwoofer
One of 2 things is going on.
First, the servo mounted in the driver may be going bad or is picking up some noise.
Second, Something in the amp section is going bad, hard to pinpoint the exact problem.
you say that it plays, so I tend to think it is the driver mounted servo unit.
If it is within the warranty time, take the unit back to the retailer you purchased it from, if not contact Velodyne for repair.
Mar 18, 2009 | Velodyne HGS-10 Subwoofer
My car sound system start crackaling when i turn it up. the sub sound fine but my 6x9s crackal and my standard door speakers. p.s only just starting doing it
Sorry to say but if your speakers crackle when you turn them up you need to not turn them up so much or buy new ones. That crackling sound is a blown speaker. It could also be a bad connection but most likely blown or under-driven speakers. Good luck.
-Andrew Hawkins
Aug 27, 2008 | Car Audio & Video
Sub woofer problem
I would check the power input otherwise if brand new return for replacement
Nov 29, 2007 | Logitech Z-5300 Computer Speakers
Cerwin Vega VE-28S Subwoofer Logo
428 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
