Question about Kenwood KVT-719DVD 7 in. Car Monitor
AVI files from USB device
I am trying to figure out how I can view AVI video files on my Kenwood KVT719 while using a USB device? Anyone have a solution?
  • Ombras Aug 29, 2008
    Thanks for the response I appreciate it.
    Champion:
  • 232 Answers
THIS OPTION IS ONLY AVAILABLE WITH AN IPOD. THE USB SOFTWARE FUNCTION ONLY ALLOW FOR MUSIC INTERFACE, U MAY HAVE TO GET A HIGHER MODEL FOR THIS FUNCTION
Posted on Aug 28, 2008
How can i play videos from a USB with a Kenwood DDX715WBT i tried MPEG-2, WMV, DIVX, AVI, but it doesnt play it shows Unsupported File.
These excerpts from the user's manual....
USB
Connecting a USB device
You can connect a USB mass storage class device
such as a USB memory, Digital Audio Player etc. to
the unit.
• For details about connecting USB devices, see
page 70 .
• You cannot connect a computer or portable HDD
to the USB input terminal.
• For playable file types and notes on using USB
devices, see page 75.
When a USB device is connected...
The source changes to
"USB"
and playback starts.
• All tracks in the USB device will be played
repeatedly until you change the source.
[PAGE 75]
USB playback
Playable files on a USB device
• This unit can play the following types of files
stored in a USB mass storage class device.
- JPEG/BMP/PNG/MPEG1/MPEG2/MP3/WMA/
WAV/AAC/FLAC/H.264/WMV (VC-1)
• This unit can recognize a total of 5 000 files and
250 folders (a maximum of 999 files per folder).
• Make sure all important data has been backed up
to avoid losing the data.
Notes on using a USB device:
• This unit may not play back files in a USB device
properly when using a USB extension cable.
• USB devices equipped with special functions such
as data security functions cannot be used with the
unit.
• Do not use a USB device with 2 or more partitions.
• Depending on the shape of the USB devices and
connection ports, some USB devices may not be
attached properly or the connection might be
loose.
• This unit may not recognize a memory card
inserted into the USB card reader.
• When connecting with a USB cable, use the USB
2.0 cable.
The maximum number of characters (when the characters are 1 byte):
- Folder names: 128 characters
- File names: 128 characters
• Avoid using the USB device if it might affect
driving safety.
• Do not pull out and connect the USB device
repeatedly while "Reading" is shown on the
screen.
• Electrostatic shock at connecting a USB device
may cause abnormal playback of the device. In this
case, disconnect the USB device then reset this
unit and the USB device.
• Operation and power supply may not work as
intended for some USB devices.
• Do not leave a USB device in the car, or expose to
direct sunlight or high temperatures to prevent
deformation or damage to the device
Feb 12, 2016 | Kenwood Audio Players & Recorders
Unsupported video file
Any video file that is .avi requires codecs. Most players don't have a comprehensive list of codecs on their chips though they have divx and xvid on many devices these days. divx and xvid are codec types of .avi. Types such as .mpg or .mpeg or mp3 or mp4 are older and more compatible with most equipment. mkv may not work
Oct 16, 2013 | Kenwood Car Audio & Video
Converted Videos won't play on my Ematic E6 jr
I suggest you try this conversion program and if it works the uninstall the other conversion programs.
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Feb 08, 2013 | Audio Players & Recorders
My LG DP122 will play some AVI files from a USB device but not others.
figured this out, lg dp122 uses DivX Home Theater profile, so the technical specs of the video must match that.
Those specs can be found here: http://www.divx.com/files/DivX-Profiles_Tech-Specs.pdf
Jan 23, 2013 | LG DP122 DVD Player, Multi Format...
Hi, I have a Samsung DVD Player H1080 R. Nice player with sleek design. When I try to connect my Seagate Go Flex USB 2.0 Plug & Play (1 TB), it doesnt play. There is data in the external hard disk,...
Good day!
These are the 2 possible causes and solution on that problem:
  • The format of the file on U.S.B device is not compatible to the format requirements of the DVD player.For example your DVD player required A.V.I or MPG/M-PEG for the video while the file format of your U.S.B is F.L.V and when you try to insert it to the U.S.B port the file doesn't read.You have to do is convert the file that store on your U.S.B device depends on the format requirement of your DVD.Use a total video converter to convert the file on your U.S.B to the format you need to play on the DVD player.
  • Or the problem could be the U.S.B itself,because the U.S.B host on this product does not supported all U.S.B device.Please try to use other mass media device such as memory card or mp3 players.
I hope this solution will be helpful.Thank you.
May 02, 2011 | Samsung DVD-H1080R DVD Player
If a file is a *.bu is it possible to view this file. Or is it possible to convert it to *.avi?
Before we convert BU to AVI, we need to figure out what is BU file format. BU files are uncommon files primarily associated with a Samsung DVR like CCTV (Closed-circuit television) recording system. Bu files contain surveillance video in a proprietary Samsung format and are playable on Samsung devices or with Samsung's video software. When you are trying to open a .BU file on Windows, Mac, media players, iOS, other portable devices, you will get the info that BU files are not supported by them.
To convert BU to AVI, we need a converting tool. Find Cicever BU Converter to have a try. It also provides a nice guide on how to convert BU to AVI here: http://www.cicever.com/how-to/bu-converter-player.html
Nov 01, 2010 | Samsung SHR-5162-250 16-CHANNEL DIGITAL...
Vids wont work
Before you put your videos on your player, you have to convert them in MTV format with the software provided in the CD that comes with your device.
Jul 01, 2008 | Coby MP-C7085 MP3 Player
My video converter won't convert saome of my vids?
1. In Menu scroll down to Setup
2. In Setup scroll down to USB Mode
3. In USB Mode there are 2 settings MSC Mode & MTP Mode, check or highlight
MSC Mode. This enables the PC to recognize the player as a removable
Device or Drive.
4. Connect to PC via USB port/cable, the PC now reads the device as
MP-C70X5 (E:)
5. In WIN Explorer click “Open to View Files”, on display will be 6 .DIR folders
& a .xml file
6. Now launch the VideoConvert.exe (application file) located on the
installation disk.
7. Click Input Video button (Browse to the folder containing .avi files) & select
.avi file for .mtv conversion
(if you want to save the .mtv file to a different destination folder click the folder
icon to the right of the Video Output text box).
8. In Output Frame Size box check 176X144 (this is the max size for this
device).
9. In Output Frame Rate box check Sports Video.
10. The Output Audio Quality box defaults to Good.
11. Click Start Conversion button.
12. The saved .mtv file can now be copied to the device by simply dragging
from its destination folder or ctrl + C & ctrl + V to the MOVIE.DIR folder in
WIN Explorer as per step 5.
13 The .mtv file is now saved to the device ready for viewing, however there is
just one remaining small lissue which may a software glich or another hassle
with this player, because whilst playing video’s every 60 seconds in the
background a womans voice exclaims what sounds like “Weeee Gamble
whatsup with that.
ionfreez
Jun 28, 2008 | Coby MP-C7085 MP3 Player
Cannot view music video on camera from pc??
Please call Jazz Products @ 732-572-7050
Mar 11, 2008 | Jazz DV-179 Digital Camera
Kenwood KVT-719DVD 7 in. Car Monitor Logo
309 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
