Blinking led light on jvc lt32p679 - Televison & Video
Is this an LCD. If so, this usually relates to some circuit failure in the TV. If you are a tech, I would start by checking the Power Supply voltages. The Service Manuals usually have some information about what this flashing means. If you are not a tech, it will probably need service but you can try unplugging for 15 minutes then rechecking. If same problem occurs, you will probably need service. Call the Customer Service people and see if they have some answer as well.
Posted on Aug 28, 2008
The blue & red lights on my JVC HD-56G787 tv are blinking alternately
Or the problem could actually be a power supply failure
Nov 08, 2013 | JVC HD-56G787 Television
Power led and lamp led blink simultaneously on my jvc hd65s998 rear projection tv
You might need to replace your lamp driver, or ballast as some call it. This is what strikes the lamp to make it light.
Mar 20, 2013 | JVC Televison & Video
Ever time I try turning it on it just says that it is in standby mode and it has a red blinking light but wont play music or anything
hi need model number to help you ..and is the blinking led in any order light or is it just blinking at regular intervals..somrtimes cd players use the led to indicate a service problem or sometimes can be in service mode accidentally..yammandan..
Aug 18, 2010 | JVC Audio Players & Recorders
Jvc gr-dv800u blinking power light when i plug it in
The camera's battery is charging while the light blinks. When the battery gets fully charged, the led will stay on, indicating that the battery is charged. The manual should explain this, in case you still have it. Good luck, and hope this helps.
Jun 05, 2010 | JVC GR-DV800U Camcorder
The blue and red light is blinking on my jvc dlp television and it will not come on. What could the problem be?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
May 21, 2010 | JVC HD-52G886 52" Rear Projection HDTV
Jvc- 36f702. Powers up then shuts down right away and the red led blinks on the front panel?
Dec 03, 2009 | JVC AV-36F702 36" TV
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
Jvc th-c50 home theater standby light blinks but won't turn on
you need to have service manual copy to check amplifier output section as it seems defective. There are few websites that offers service manuals download for small fee.
Jun 11, 2009 | JVC TH-C50 System
JVC AV-27020 TV Blinking LED, Static Electricity on tube but no sound and image
Sounds like a bad main regulator IC.. Try putting a 100 watt light bulb across the main AC fuse, turn on the set and see if it will stay on longer. If it does, replace the main regulator iC. If it does not, then it could be almost anything in the sweep section of the set, and or in the regulation circuit of the power supply. Look for slightly swollen capacitors in the set. good Luck please do not forget to rate this thread.
Dec 10, 2006 | JVC AV-27020 TV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
