Question about Vacuums
How to dismantle a Kambrook KBV30 vacuum for servicing? Does it require a special tool?
Nope, just a screw driver. The key are the covers for the handle. Just pry them apart from the body. Then you can access the screw holes that hold the two body parts together. Took mine apart as the motor sparks a lot and you can smell loads of ozone. Seems like the coals that connect the power to the motor are broken or unevenly burned away. Rest seems fine will try to replace the coals.
Hope this helps
Buzz
Posted on Nov 08, 2008
Replace pump in model 7920
You're better off letting a small appliance store service dept handle repairs on this unit. They require tools to dismantle them.
May 15, 2012 | Bissell 7920 ProHeat Pro-Tech Upright...
Type your problem for a solution...
Let a repair facility such as Sears repair it. They require special tools to be dismantled.
May 15, 2012 | Bissell 7901-1 ProHeat Scotchgard Upright...
The motor is working but brush not spinning
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing a DC07, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Oct 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 brush not turning belt is intact?
DC07s have two drive belts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
Have a look atwww.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07, but unless you have access to such tools, and feel confident to tackle it, it's probably time to callDyson or a Vacuum repairer.
Sep 30, 2010 | Dyson DC07 All Floors Bagless Upright...
My roller brush no longer rotates?
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Sep 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brush no longer spins when in the carpet position.
DC7s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
Aug 17, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i change the bely on my Dyson rootcycle
DC07s have two belts - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
I suspect the belt you are to refering to is the one from the clutch to the brush bar. Unfortuenately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing your machine, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Mar 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush is not spinning. Belt is intact and ok.
Feb 28, 2010 | Dyson DC07 Allergy Blue/Turquoise Bagless...
The beater bar will not rotate but the belt is not broken.
I suspect the belt you are to refering to is the one from the bar to the brush. Unfortuenately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
Feb 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The brush is not turning, looks like the belk is ok but don't know how to get to the belk
Unfortuenately the belt that connects the motor to the clutch is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
Feb 08, 2010 | Dyson DC07 All Floors Bagless Upright...
Vacuums Logo
188 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
