USB Can'nt formatted
I am trying to format my pendrive. After giving format command it showing Windows was unable to complete the format.
  • rudra_sakti Aug 28, 2008
    My Operating System is Windows XP
  • Josh Peters
    Josh Peters May 11, 2010
    What operating system are you using?
  • 52 Answers
Well if you are going to my computer > Selected Drive > Right-Click On Icon > And Click Format > Quick Format > Start
And it should be done. If not check to see if the drive is not set on lock.
Posted on Aug 28, 2008
Unable to write bootable iso image on pendrive, Write method changed after selection of iso
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
hope this helps
Sep 25, 2012 | Sony VAIO E Series SVE15115FXS Laptop
Hello, i am not able to format my transcend 8gb pen drive. whenever i format this pen drive after a few second's i got a message "WINDOWS UNABLE TO FORMAT". Properties shows used space 0 bytes and free...
Try it on another usb port..or If the windows can't format try formatting it from the command prompt if it's not working than must be pendrive.. i think there's no problem with other pendrives.. or the one that you have
Aug 18, 2010 | Computers & Internet
My kingston 32gb pendrive not format , how to format my pendrive please give me step by step solution thanks & reghardes subhash
normaly your pendrive not formated so cmd (command prompt) use.
Run - cmd (type) than enter
format (pendrive colon) than enter
continue process which computer show
your pendrive is formated.
Apr 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pendrive software
if window is unable to format try to format it using some utility software like hp disc format utility
download link
http://files.extremeoverclocking.com/file.php?f=197
Apr 05, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pendrive is not formatting
You need to change your pendrive as there is a manufacturing defect which generally arises after some time of using pendrive
Jun 09, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Unable to format pen drive
XP has a stupid feature like that. If you did format with the XP style, try to do it manually.
My computer > Locate your usb pendrive >Rightclick and Format.
If this don't work, your pendrive might just be malfunctioning. Replace it if you can, or upgrade to external harddrive.
May 20, 2009 | Sony Computers & Internet
Enable to format my usb pendrive
your pedrive contains {Autorun} virus that's why you are unable to format it to view this virus go to view option in control panel then view and tick the show hidden file and folder
you can remove this virus
install malwarebytes and scan your pendrive
when you remove the virus format your pendrive
IF it not works
I think you use windows xp that's why it happen
Try to format in windows vista .or in windows 7
Apr 14, 2009 | Alpha Digital 1 Bay (HD360SU) Serial ATA,...
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
windows was unable to complete the format 4gb moser beer
Feb 26, 2009 | Electronics - Others
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
