Question about Ricoh CL4000DN Laser Printer
Lanier 5622 Prints vertical lines
I have a Lanier 5622 that had its toner replaced about a month ago. Now I have vertical lines printing on all my printouts and copies. This started about 20-30 days later so I dont know if the problem can be attributed to the toner but even if i copy a "Blank Page" the streaks still show up. There are no errors appearing on the display panel. I tried installing a new fuser and maintenance kit today but the problem persist. I also cleaned a long rectangular glass that slides out by the toner but the alas the problems continue. I've tried cleaning everything but lines still appear. Any help or ideas would GREATLY be appreciated
  • 62 Answers
Bad PCU
Posted on Feb 10, 2010
    Problem Solver:
  • 10 Answers
You could remove the color and black&white drum units and check from below the units to visually observe lines on all the 4 drums. If so, you have to change the drum unit/units. Drums occassionally get damaged before life this way due to solid toner particles inside the toner bottle.Always "shake the toners very well" before replacement, and if you print rarely, then remove the toners and do the shaking to prevent clogging due to inactivity.
Posted on Oct 03, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
Hp cm2320nf prints 2 black lines vertical all the way down pg 1/2' apart
Remove cartridge observe on cartridge drum finds any vertical toner line? replace cartridge, as well as check all cartridges same manner...if found replace them..If its only on copying: clean flat bed both glasses..with glass cleaner..
Feb 02, 2012 | HP Laserjet CM2320nf All-In-One Color...
Our Hp 5550 prints thin vertical black lines on high res images. They are evenly spaced (3cm apart on an A4 print).
This is caused by a damaged drum. The drum is the long metal cylinder inside the toner cartridge. You will have to replace the hold cartridge. You should be able to flip a plastic cover on the toner and see the drum. If it has black toner lines then it usually means the drum is scratched and there for toner fills the scratch and produces lines.
Replace the print cartridge (toner cartridge) and the lines should go away.
Jul 19, 2011 | HP LaserJet 5550 Printer
Brother 2040 yellow toner light on & won't print. Toner just replaced 8 weeks ago. Printer purchased 6 months ago.
You have a one year warranty with Brother if you need repair. You might shake the toner, or put a small electrical tape over the little round windows on the toner cart. to use the rest of the toner, and press the go button 3 times to print the report that tells you how many prints you've made, you could just be out of toner again...
Feb 03, 2010 | Brother HL-2040 Laser Printer
Prints a line in a page
if that line is horizontal and repeat itself on the page then the problem should be from the Drum of Toner.(should be fixed if you replace Toner)
if it is vertical line all over the page then it ia allmost the fuser film (torn vertically) and if so you should send the printer to a specialized technician
Nov 26, 2009 | HP Office Equipment & Supplies
Prints thick black lines
Hello, Andrea.
Sounds like either your printer needs a new fuser assembly (If the teflon roller gets scratched or starts to disintegrate you will get lines or black marks on the page) or you need a replacement toner.
Hope this helps.
Sep 14, 2009 | Brother HL-5240 Laser Printer
HP 2600n prints some blue vertical lines
1 of 2 things: First, check yuor Cyan cartridge and make sure that it is not leaking. It may have a bad seal. If you replace it with a known good toner, the imaging unit (the black acetate thing) will need to be replaced. This is also a consumable unit.
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Ricoh CL4000DN Laser Printer Logo
490 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
