Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE D52GW12 turns off shortly after being turned on.
I have a approximately 3-4 yr old GE D52GW12 that turns off shortly after being turned on. any thing i should look for? i want to give it to my dad, if i can fix it. i just recently purchased a 50" plasma tv, so no need for a old projection style tv.
Thanks,
Mike
  • Anonymous Feb 20, 2009
    TV flickers on and off continously, cant afford a new set so looking for a simple do it yourself fix.
  • GE Master
  • 8,617 Answers
That model is famous for bad flybacks. It uses flyback number 265409 you can get a replacement at the following link with free online tech support that will explain how to install the replacement. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Aug 28, 2008
GE D52GW12 TV TURNED ON WORKED GOOD FOR 3 MIN THEN SHUT OFF . WENT TO TURN IT ON AGAIN AND GREEN POWER LIGHT BLINKED AND HERD A POP OR CRACK NOISE ..NOW DONT TURN ON . SEE 1 OF THE TUBES FLASH IN FRONT 1...
The CRT on the left will need to be replaced. You can test it by removing the CRT drive board from the bottom of that tube and leaving it suspended without unplugging any wires. try plugging it back in and pressing power. If it powers up with that drive board hanging off the bottom of that tube then you know thats the issue and the CRT ( tube) will need replacement. You can get the replacement CRTs ( tubes) from www.tvrepairworld.com
Jun 14, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
ON our GE D52GW12 52" AFTER TURNING TV ON IT
Try resoldering the flyback transformers connections on the board. Its very common for the flyback pins to develope cracks around the pins which can cause that issue. I would check that first with that model.
Jun 13, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Power light blinks but will not turn on
The ge d52gw12 is a ge version of an rca itc 222. i have worked on hundreds of these at the shop and found with the ge modle 95 percent of the time it is a bad flyback transformer and a shorted horizontal output transistor. While there can be any number of things at fault. This is the first thing to check in this model. At our shop this repair averages 100 to 150 to repair. this varies depending on your location.
Mar 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sony ps 3 won't show initial screen. turns on/grn light is on indicating but nothing happens/ have chgd the rca cables/ chgd tv's/made sure not dusty chgd all inputs/still no resp//any ideas? also, no...
Turn off the PS3. Press the power on button (the system will beep) and hold it down for approximately 5 seconds until you hear a second beep. This will reset the video to the default. You should get a low resolution screen and be able to log on and reset the display to the desired settings.
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
My ge 52' hd rear projection tv wont turn on.
replace the flyback you can get a replacement at the following link leave a email with your model number and they will respond quickly with which flyback you need they also provide free instructions with pictures on how to do the repair.
Mar 14, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Need receipt for refund?
With a set this old Company will not refund anything, So ck capacitors cp114,120,150 if any of them are puffed up on tiop replace all 3 capacitors.cp150 2200uf 16v use 25v and other 2 are 220uf 35v.resolder all pinns on FBT flyback transfomer.
Feb 15, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have the same problem, what the heck. it's over for it
Jun 09, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
225 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
