Question about Kitchen Ranges
I have wired my stove correctly but there is no power from the power switch, also non of the outside lights are working.
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
You can not remedy electronic problems your self!
service needed
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
3 plates stopped working and the 4th one does not switch off.
unplug the unit and gain access to the wiring connection for all 4 elements(plates). remove the wiring from the element that will not shut off. while making sure none of the unconnected wires do not touch any metal or another wire, and plug in power cord. if the 3 non-working elements get hot then replace the none working control knob
Apr 03, 2014 | Stoves Kitchen Ranges
Burner will not get hot enough
When the burner arced out it probably also ruined the switch. Most switches on a standard electric range have 5 wires. 2 wires to the burner. 2 hot wires from power and a smaller wire which connects to the indicator light marked P. It is easy to test the switch Unplug the stove. Turn the suspect switch on wide open. Check for continuity between the 2 terminals going out to the burner marked H1 and H2
If you cannot get a reading then the switch has failed. Note: when replacing the switch usually on most stove the replacement will not be or look like the original HOWEVER it will still have L1 and L2 H1 and H2 and P but the terminals are not always in the same order. If you fail to correctly connect the new switch you will fry 2 switches when both get turned on. Ouch!
Aug 30, 2012 | Kitchen Ranges
Pilot on GE stove keeps popping non-stop
As far a "popping" do you mean the igniter on the cook top "clicking"? Did you clean the range and use too much water? If water gets into the igniter switches they will short out and constantly click. Also if the polarity at the electrical plug you can get what is called "ghost spark" so make sure that the polarity is correct at the electrical outlet. Each gas control valve has a switch that turns on the igniter when the knob is in a certain position and they are all wired in a sequence. One of those switches may be shorted out or have a loose wire(range dis-assembly required to inspect). Do you visually see a spark at the electrodes of the burners or do the burners ignite? If you cannot see the spark then there may be a grounding issue and possible loose wire.
Sep 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont work,stove (burners work fine E1, f5 error codes
HI. this is a self clean latch malfunction code.
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Sep 02, 2009 | Whirlpool Accubake RF362LXTT Electric...
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Infinite Switch on Amana Stove
I would start with P1. The "P" terminal is for the "element on" indicator light on the panel. Start with P1 then turn on that element and check the light for operation. P2 is most likely a loop through. Hope that helps.
Oct 31, 2008 | Amana Kitchen Ranges
RF367LXKQ burner light always on
YOU HAVE A BAD STOVE SWITCH,TAKE THE TOP BACK PANEL OFF STOVE,HOW FIND OUT WHAT COLOR WIRES GO TO THE STOVE LIGHTS,NOW ONE SWITCH AT A TIME REMOVE THOSE WIRES CHECK TO SEE IF LIGHT GOES OUT NOT RECONNECT WIRES AND MOVE ON TO THE NEXT SWITCH UNTIL YOU FIND THE BAD ONE THE REPLACE IT,HOPE THIS HELPS-MIKE
May 30, 2008 | Whirlpool RF367 Electric Kitchen Range
Stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Jan 10, 2008 | Kitchen Ranges
Kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Dec 03, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
