Question about Pentax Optio S Digital Camera
SD memory card problem
I just bought a optio S and i absolutly love it. the only problem i have is that the camera write these protection code on my SD card and i have no way of cut and paste, or edit the pictures or delete them when im trying to read the SD card with the lexar jumpdrive trio. i installed all the drivers and stuff for my camera, and i still cant delete and pictures off the SD card with a reader. im not sure what i did but it seems my laptop is the only computer that could access the card. tried it on different computer and i couldnt get pass the protection on the card.
    Master:
  • 542 Answers
Have you tried sliding the little switch on the card out of the "lock" position?
Posted on Sep 08, 2005
SOURCE:
Card unlock pentax optio
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 10, 2013 | Aqua Pentax Optio S12 Digital Camera
How do i unlock memory new memory card on optio 550
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 26, 2012 | Pentax Optio 550 Digital Camera
Pentax Optio T10,comes up with Card Locked, when turned on
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 23, 2011 | Pentax Optio T10 Digital Camera
The memory card on my pentax optio camera is locked. a yellow key appears. i found the display showing the key but cannot find the function to unlock it
Oct 25, 2010 | Pentax Optio E30 Digital Camera
How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 22, 2010 | Pentax Optio W10 Digital Camera
Pentax digital camera optio s memory card locked
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 25, 2009 | Pentax Optio E30 Digital Camera
Memory card
Hi and welcome to FixYa.
Your camera will not work with an SDHC card. It must be an SD card.
Don't forget to format the card in the camera after you install it. Elsewise it won't work properly.
Thanks for coming to FixYa, and feel free to rate my solution.
Rob
Jul 28, 2008 | Pentax Optio T10 Digital Camera
Memory card not working
Not saying it is, but are you absolutely sure its not the camera software itself. Does it have any warranty? Is the card a new card and have you made sure that the TAB on left of SD card is not allowing READ ONLY. The tab flips up allowing the card to be formatted bit like the old floppy disks.
Apr 26, 2008 | Pentax Optio T10 Digital Camera
Optio 30 SD Card Max Size
You can now get up to 2.0 Gigs (that's 2048MB) of storage on a MiniSD card and all you would need is a SD Adaptor. The following site has MiniSD cards that are 1.0Gig (1024MB) or 2.0Gig (2048MB) and they come with FREE adaptors! http://www.flash-memory-store.com/mini-secure-digital.html As technology increases so will the story size. They are talking about making MiniSD cards that are up in the 5.0gig (5120MB) area. Enjoy!
Aug 30, 2005 | Pentax Optio 30 Digital Camera
Pentax Optio S Digital Camera Logo
75 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
