Computers & Internet Logo
Posted on Jul 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Eye trying to down load microsoft chip, to clean my registry
Anonymous
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Jul 18, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
5763
Points
112
If you want to clean your registery and other extra files
download ccleaner its free and all registery will clean
Turn on computer it takes about 15 mins to get desktop up
It depends on how much application you will need to load. Sometimes corrupted registry or virus will slow it down.
You can check the following link for some hints about how to clean and defrag your hard disk and perform a scan online.
http://www.microsoft.com/atwork/maintenance/speed.aspx
With the follow link, you can perform a diagnose of windows system and fix some configuration and registry issues automatically.
http://support.microsoft.com/gp/slow_windows_performance
Trying to loggin to my face book i put my username and pass word but then it will not load the home page at all so unable to get onto my facebook.
corrupt windows registry cause freezes in computer. With passage of time, registry becomes congested and corrupt. Registry is most vital part of the computer system that stores and use vital information.A neat and clean registry ensures smooth and fast computing. Clean registry means no Facebook kind of freezes. For this, you need to use the best registry cleaner. It will solve the problem of such freezes. Registry cleaner reg in out should be used regularly. Additionally, it will speed up computer for all other programs.
So I got a new hard drive installed from Dell. Everytime I try to load Microsoft Office (even a new version downloaded from Microsoft's website) it crashes the computer. I get the blue screen that says...
there is a registry error in your HD, you need to rectify that by installing any registry cleaner(try Tuneup Utility...downlaod from piratebay)...if that does not solve the issue....only a low level format can clean the HD...format your C drive only if you have multiple partitions in the HD
2answers
Loaded Windows 7 Tried to get as many drivers as
Install the chip-set utility first upgrade bios if needed, check ahci mode in bios
2answers
Computer loads real slow
Please provide more details about your computer viz., operating system, hardware configuration etc
In the meantime try using msconfig.
for more details on troubleshooting using msconfig
1) Windows XP
http://support.microsoft.com/kb/310560
2) Windows Vista
http://support.microsoft.com/kb/331796
4helpful
Error 1316 occurred while down loading adobe 9.1 what is wrong. Wiil not let me down load any registry fix.
Hi upperroom50,
This message usually means a previous installation of a software is getting in the way of the new installation. It's kinda nutty that this would cause a problem, but we live in a nutty world. The fix is to download a free program from Microsoft that will totally and completely remove the old software. Then the new version can load unimpeded.
1. Download: Microsoft Windows Installer Cleanup Utility
2. Choose Save file option in the popup dialogue box
3. A File by name Msicuu.exe will be downloaded on your system
4. Run the Msicuu.exe application. This will install the program.
5. Run the Windows Installer CleanUp Utility file you just loaded (Start > All Programs > Windows Install Clean Up or C:\Program Files\Windows Installer Clean Up double click msicuu.exe
6. You will see window listing various applications.
7. Select the offending program, then click Remove. You'll see the warning box, select OK. The utility will remove all the parts of the program from your computer.
8. Restart your computer, then try loading the new version of the software.
Good Luck, and don't forget to leave a rating,
Thanks
Mark
1helpful
It loads to a certain point, then I get a blue error screen
Try to restart the computer in safe mode and uncheck the items not related to Microsoft from start menu
Microsoft office outlook, word, excel all stop working-shut down
you can try fixing the problem by diting your registry.
1. go to your desktop.
2. on your keyboard, hit the "windows key" (between ALT an CTRL) together with the "R"
3. a little box should pop up. In the box, type "regedit" and press enter.
4. registry editor should open up. (it looks something like windows explorer)
5. navigate to the following registry key: HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Office\ Outlook\ Addins\ Microsoft.VbaAddinForOutlook.1
6. Right click on the "Microsoft.VbaAddinForOutlook.1" and delete it.
7. close registry editor,
8. restart PC and run outlook!
1helpful
Lines in the picture but no red lights
is it under warranty? if it is get a new one. if not you can open it andclean it out as good as you can. its getting hot on the video chip and thats why.
Office 2007
sounds like a HD problem run error correcting utility, and defrag the hard drive, cleaning the registry helps too.
also make sure you have shut off any virus program some dont like it when a program is being installed especially norton ineternet security.
check the disk make sure theres no scratches on the cd.
also bad memory will cause errors. try removing a chip from the computer and installing. ive notice when installing OS's like win xp if you have a bad memory chip it will not install.
Also you can try a different CD rom drive, the one you have could be failing.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Grand Canyon Tech
Grand Canyon Tech
